Question about Samsung Computers & Internet
Samsung main power supply desk top monitorS20A350BS desk top
Samsung desk top main power cable S20A350B
    Top Expert:
  • Samsung Master
  • 12,223 Answers
You must measure the output from your power supply see the diagram attached in the box. If some Voltage like +5vdc is missing you must replace the power supply. If the Monitor NOT turn ON try to test in another computer more easy. or go to the repair shop.Use the bottoms from the monitor and execute from the MENU make test.
God bless you
Posted on Jul 28, 2013
2 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: power supply fo acer Aspire SA 60 desk top
To my knowledge, there is no limit to the maximum wattage that can be installed in your PC. The only limitations would be:
  • the physical dimension and mounting holes;
  • the connectors and wire/pin arrangements;
  • it should not be lower than what you currently have.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 23, 2008
Compaq laptop
Unplug power adapter from laptop and remove main battery, press and hold power for 2 minutes, when finished install battery and power supply. Now turn on the computer.
May 03, 2012 | Averatec Computers & Internet
Need a 400W power supply for a HP774y Pavillion Desk Top computer. It must have the dimensions 4 x 3.5 x 6 ish. the cables must come out on the right side (when viewing the fan opening side. Neither...
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacemnent from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Aug 22, 2011 | HP Bestec ATX-1956D 200w HP Part No...
Hi Help desk, My Samsung SyncMaster 540N LCD monitor is taking hours of time of display the desktop.what might be the case?Is it due to CAPACITORS popping out? Need a damn help from...
hi there,
Yes, it's capacitors issue.
I will explain how to fix it:
  • Open the case of the LCD
basically in all LCD monitors have two circuit boards (power supply board and system board)
  • After you open you will see the two boards are
  • You see a board that has a socket for the power source. wrote that the board we're looking for (power supply board)
  • Remove all cables connected to the board and take out the board. (get noted before you unplug it)
  • Now you see it components on board, we looking for capacitor.
  • Looking for damaged capacitors, physically you will see a capacitor on the top like a bloated
  • Replace that capacitor. Done
For More details please read my tips here
Please let me know the result
Thanks.
Dec 16, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Cannot start my dell inspiron 570 desk top computer with the power button in front of computer
cannot start my dell inspiron 570 desk top computer with the power button in front of computer
Sep 16, 2010 | Dell POWER SUPPLY Power Supply
My Samsung 32" LCD TV keeps turning itself off then back on. We think the problem might be the remote (BN59-00598A). Have you ever heard of this problem and do you think it's the remote?
You may have a power supply problem. This model year of Samsung TVs had a part Capacitor issue. Symptoms vary by model, but most often they take a long time to come on (clicking on/off/on/off). Locating the parts is easy once you have the rear cover off. The bad caps have swollen tops and are near the cable that connects the power supply (AC cord has a connector which plugs in to it) to the main PCB (board that your cables plug into). This connector is located at the top right of the power supply. I have a tutorial on solder here on FixYa, click on my user name to have a look if you like.
Mar 16, 2010 | Samsung LN32A550 32 in. LCD TV
I have two desk top pcs, and two cable modems. how can i connect the other pc using one of the modems without paying for another cable bill?
get a wireless router and usb dongle for the second computer. Establish a home network and connect the wireless desktop to the existing cable modem via the wireless router.
Sep 27, 2009 | Computers & Internet
Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Aug 12, 2009 | Samsung Televison & Video
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Problem in desk top computer
CHECK ALL CABLES.
YOUR MAINB POWER SUPPLY BORD MAY NOT WORKING ...
CHECK THAT ONE 1 ST....
dont forget to tell me u r problem solved or not
best regards & best of luck.
Oct 23, 2007 | Audio Players & Recorders
Computers & Internet Logo
51 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
