Question about Kenmore 3/4 hp Food Waste Disposer
Kenmore 3/4hp disposal only hums. Reset button is pushed in. Crank wrench moves freely. I found nothing in the chamber. Thanks.
  • Kenmore Master
  • 5,089 Answers
Why isn't it turning on?
Melody, check fuse/breaker,could be clogged/jammed, motor maybe defective.
Apr 15, 2016 | Garbage Disposals
How do I unjam it?
On the very bottom of the disposal there is a small opening in the very middle of the disposal. If you shine a light under the sink and put a mirror down on the inside of the cabinet you should be able to see this. You'll need an Allen wrench to put in the 6 sided hex hole and turn counter clockwise until the disposal turns freely. This should unjam your disposal. Don't forget you may have to hit the small reset button on the bottom too.
Jan 14, 2016 | Garbage Disposals
How to fix a stuffed garbage disposal?
It should have come with a Allen wrench. Be sure it is off. Insert it in the bottom into the center hole. Move it back and forth several times until it frees up. Remove wrench and try, you may have to do this several times. Also be sure the unit is reset before turning on. If it does nothing nor makes nay noise it is probably tripped.
Aug 08, 2014 | In-Sink-Erator Evolution Pro Cover Control...
Kenmore 3/4 hp garbage disposer does not work, it only hums.
Do not turn on... humming sound will overheat motor
See if cutter disc located inside disposal can be moved and rotated using broom stick:
If disc rotates freely, then try motor again... if still hums, then replace disposal
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene h
Mar 25, 2014 | Kenmore 3/4 hp Food Waste Disposer
Kitchen aid kadette 250
with the power "off", check inside the unit to make sure nothing is jammed in there. assuming the interior is clear, try the reset button which is usually located on the bottom of the unit. may need to use a mirror and a flashlight to locate it. if the unit hums (indicating power is there) but it does not rotate/turn/work, use your "disposal key" or a hex wrench to turn it manually: usually inserts on the bottom-middle of the unit; turn it both ways to free it up.
Jul 05, 2013 | Garbage Disposals
Reset button not working
Try reset button on bottom of disposal.
Following link has full troubleshoot resources:
If reset will not restore functionality, check that unit is getting power, and then check that unit is receiving 80% rated voltage. Replace disposal.
Add a comment
Jun 20, 2013 | Whirlaway Garbage Disposals
Kenmore 3/4 hp Food Waste Disposer Logo
315 people viewed this question
Top Kenmore Garbage Disposals Experts
Gene Haynes
Gil Shultz
ray gallant
Are you a Kenmore Garbage Disposal Expert? Answer questions, earn points and help others
