Question about Altec Lansing FX3021 The Expressionist Plus Music System for Computers/MP3 Players
How do i take off the bottom of the subwoofer to fix the SAT input that had shifted out of place ?? took screws out and bottom seems to be undetachable
Can my powered subwoofer be fixed?
Possibly, It took a while but I had a pair of 25 year old JBL Subs repaired after many said they cant be fixed. Have a look on line or in the phone book for your nearest amplifier / speakers / musicians electronics repair shop.
Apr 08, 2015 | Audio Players & Recorders
Tip
How to make a Dummy load for Cb radio
I took a "Pringles chip" rounded container and wound 8.25 ft of fine copper wire around it from top to bottom with a screw up top(bore into cardboard) holding it in place, and a***Shiny" screw **attached to the metal bottom. Then i took 8.25 ft. and placed it inside of the Pringles can. I punched a hole into the plastic lid and pulled through the wire to go to ANTENNA INPUT. Sitting it on top of the radio I let the metal bottom touch the GROUND by a screw. I keyed the radio it matched the same as my Antenna did. It keyed the exact same 1.5 watts and swinging to 4 watts when I whistled on my PC68Xl Uniden 40 ch. CB radio. Make sure both ends are stripped of enamel coating by scraping it off. I use a cigarette lighter for this or my teeth, or rough sandpaper, or nail polisher. The screw up top of canister is not important --it just holds the wire,so to easy wound the wire. I gapped it about 1 inch apart between windings.
on Apr 01, 2011 | Radio Communications
My Infinity HPS-1000 Subwoofer when turned on wont stay on. What could be the problem ?
Could be many things. The control panel on these have been notoriously problematic (check the forums). Mine sat for a couple of years because it would power on. It just took longer and longer and then nothing. But I couldn't part with it; the way it made the house feel when it worked. But there doesn't seem to be any repair shops around anymore. So there is this shop on Ebay watched and checked the feedback. I coughed up the $178 and they did something to fix it. I don't know what. I don't care. It worked. Here is the link, looks like they are still doing it.
WE REPAIR INFINITY HPS1000 AMP JUST SEND US YOUR NON WORKING AMP WE REPAIR...
Mar 07, 2015 | Infinity Audio Players & Recorders
Need to fix a kicker l7 15" subwoofers blow the coil
If you have a direct replacement, unscrew the speaker from the case, the cables to it are either terminals or soldered on place so disconnect those, then reconnect the new cone the same way round as you took off the cables and screw back into place.
Jul 22, 2014 | Car Audio & Video
Pioneer vsx 519v
Are you sure the correct input is selected on BOTH the TV AND the A/V receiver?
Does the subwoofer work on other inputs? If not, is the subwoofer connected correctly? If so, is the input connected correctly?
Jan 31, 2014 | Audio Players & Recorders
Open sonos play 5
Okay, so I literally just took mine apart, a screw came out that was holding the subwoofer in place and it was causing horrible distortion and vibration.
First off there are a bunch of screws you need to remove, all phillips heads thank god. The front grill just needs a little bit of tender pulling, start at the seams on the sides and pry it out, its only held in there by some velcro material on the front and how tight the sides slide into the rest of the unit, so it shouldnt be too hard to remove. Once it's off you will see all of the screws that need to be pulled out, they are all the same length and there should be 6 of them.
After that you will need to flip the Play 5 upside down and pull off the rubber bottom plate, its held on with a tacky adhesive but its pretty easy to pull off. You will see that there are now a bunch more screws to undo at this point, including 2 stickers over two of the screws saying if you remove or break you void the warranty (Sonos warranty is 1 year, so if it's beyond that, go for it). You pull off those screws as well, pretty sure there are 6 of one size and 2 of a skinnier size. This will easily remove the bottom plate.
From there you can now access a few more screws that will then allow you into the system. I hope that this can help you fix it or you got brave and tried it yourself at this point.
Oct 14, 2012 | Sonos PLAY:5 Black All-In-One Wireless...
Mirage s8 subwoofer is emitting a constant hum
that is just the radio from the input,its normal
Jun 19, 2010 | Mirage Prestige S8 Subwoofer Speaker
Rear speaker rattles in 02 Montero Limited
That cover doesn't come off - It's screwed (4) from behind. You have to take the upper trim piece off (and handle) to remove the bottom trim piece and access the subwoofer. If your sub is like mine, the foam all the way around the sub has torn away, making it rattle. There are only 4 screws holding the sub in place, and it's sticky taped to the wall, so you may have to pry it off. Hope this helps!
S
Aug 29, 2009 | 2002 Mitsubishi Montero
Subwoofer cuts out
Its due to the damaged pin in which you r inserting the subwoofer pin!
Dec 08, 2007 | Audio Players & Recorders
Altec Lansing FX3021 The Expressionist Plus Music System for Computers/MP3 Players Logo
21 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
