Question about Sony STRDH520
Have to reset Sony STR-DH520 to factory default each time play DVD
Each time I play DVD on Sony Blue Ray DVD play thru my Sony STR-DH520 Receiver, I have to reset the receiver to factory default settings (holding power button to clear settings). How do I keep the factory default settings on receiver so that I do not have to go thru the same effort each time?
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
SOURCE: "Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Posted on Nov 28, 2008
SOURCE: Sony STR-DG520
STRDG520 requires that the audio is from the digital optical or the digital coaxial to have sound. Just add digital audio from blue ray player to the amp and your good to go.
Posted on Dec 28, 2008
mlapres
  • 757 Answers
SOURCE: Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Posted on Jan 18, 2010
Testimonial: "Thank you excellent report spot on with the hook-up. Will buy new receiver. John McMullan."
adracamas
  • 344 Answers
SOURCE: I NEED TO RESET Sony STR D365 Receiver BACK TO
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Posted on Apr 11, 2011
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
STR-DH520 Sony av receiver , Protect sign keeps coming on and I have no wires connected at all! How can I fix ??
There is most likely a short in the amp that needs to be repaired. Probably a pair of shroted output transistors as well as a few resistors will need to be replaced.
Dec 17, 2014 | Sony STR-DH520 A/V Receiver
Dh520 protect mode
Usually means you have a blown amp channel. Shorted output transistors and burnt resistors.
Oct 06, 2014 | Sony STR-DH520 A/V Receiver
Will the Sony STR-DG820 receiver support 3D?
I have this amp and mine does not have the latest firmware (indicated by a green or blue dot near the serial number) and it does not pass through Audio or Video when a 3D Blu-Ray is played in my PS3 although my TV (Sony Bravia XBR-52HX909) does say "3D Video Signal Detected." No audio or video ever plays but the PS3 looks like it's playing.
Dec 31, 2010 | Sony STR-DG820 Receiver
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
Sony STR-DG520
Nov 09, 2008 | Sony STR-DG520 Receiver
HDMI Connection
is the hdmi connected to the tv
Apr 09, 2008 | Sony STR-DG510 Receiver
Only decoding in pro-logic
go in blue ray dvd menu as dvd is playing and select the audio out formatt u wann use has to be on 6.1 or least 5.1 digital not 2.o ch ok and u may be seding the digital with the hdmi outs not both be hard for it to do doe syour tv had digital opti out run that to reivciver on digital input ok tell blue ray options menu also digital oput bitrate ok
Jan 18, 2008 | Sony STR-DE835 Receiver
Sony STRDH520 Logo
140 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
