Question about Garden
DAUCR WEEDEATER HOW MUCH OIL DO I PUT INTO MOTOR
  • 1,807 Answers
2 stroke mix should be 50:1
50 parts fuel to 1 part 2 stroke oil.
Posted on Jul 27, 2013
I have a Troy Built weed eater, that sprays oil out of the side when i try to crank it. But will not start, its a 4 cycle.
Hi Bruce:
That does not sound good. How long have you had it, did it ever run well, and what happened immediately before you discovered the problem? Some history may help discover what caused the problem. Once you find the cause, the fix is usually known.
Without a doubt, the worst weedeater I ever had was a 4 cycle, and I've gone back to the 2 cycle.
I think the biggest problem with the 4 cycle for a weedeater is that the position of the motor is not constant, so the oil in the crank case ends up against the piston.
As for trying to solve your problem, I'd start off by:
1) cleaning the motor so you can see exactly where the oil comes from.
2) make sure that the oil is at the correct level and not overfilled.
3) Remove the spark plug and make sure it's clean.
4) Use the start cord to spin the motor over a few times to make sure excess fuel and/or oil is blown out of the cylinder.
5) Check the spark at the plug tip. Should be hot and blue.
6) Put the plug back in, fuel it up, and try to start.
Now you get to look for the source of the oil, and since you know you have spark, the only other thing it takes to make it run is a functioning carb.
Jun 19, 2015 | Troy Garden
I put seafoam in my weedeater with on mixture of gas and oil and it runs better why
It can get its air easier. When using too thick an oil in the filter, sometimes the carby cant breathe properly and it will cause the motor to stall.
Aug 13, 2014 | Homelite Garden
Weedeater 380
Hi Nick, Ryobi Weedeaters are all two stroke. They need a fuel to oil mix of about 40:1. This is why they dont have anywhere to put oil in. It goes with the fuel.
Jul 23, 2013 | Garden
What kind and how much oil to use in a ryobi weedeater S430
2 stroke oil probly runs 50:1 mix most of time there's mixing instructions on your oil jug reminder better to have to much then to little not enought you could blow your motor
Mar 03, 2013 | Garden
Unsieze a weedeater motor after using regular gas
Even if you are able to "unseize" it, it may not run afterwards. The reason you NEED to add oil to the gasoline is because that is the only lubrication the engine gets! You can try to unseize it by removing all of the remaining gasoline from it and putting in ONLY some 2 cycle engine oil. Then you will need to attempt to turn the engine shaft back and forth using the weedeater feed spool as a lever handle. IF, and I say if it breaks loose you may not have sustained alot of damage. If it doesn't...
Jan 10, 2013 | Garden
What oil am I to mix with gas for my Husqvarna 125RJ weedeater?
any 2 cycle oil is good.
mix 40 to 1 for most 2 cycle motors
Jul 07, 2011 | Husqvarna Garden
Ratio for oil and gas on a ryobio weedeater
if you are using stihl oil the ratio is 50:1
Jul 03, 2010 | Ryobi Three Trimmer Combo
Weedeater Hedge Trimmer
It's a 2-cyle engine. The oil is in the gas.
Jun 06, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
Wont start
try and change the solenoid!!
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
