Question about John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers
Adjustment how to adjust pto clutch
    Sergeant:
  • 224 Answers
On the front of the clutch, you should see 3 or 4 bolts with springs under them, they are the adjustment screws. Insert a .018" feeler gage between the clutch's plates and tighten the screws. You will have to go around to each screw several times as adjusting one effects the setting at the others.
Posted on Sep 04, 2013
How do you adjust pto elec clutch
Generally, electric PTO clutches are non-adjustable and will have to be replaced if malfunctioning.
Jun 17, 2015 | Garden
HUSQVARNA Z4824 O TURN MOWER - NOCKS WHAN PTO IS INGAGED & STALLS
need throttle adjustment govenor adjustment possiblt new pto clutch you have to take in to shop adjustmets 50.00 pto clutch 200.00
Sep 03, 2014 | Garden
Blades wont engadge belts on
This would be either the clutch relay, pto switch or pto clutch, check the relay first, then the pto switch, and lastly, check the clutch, if the clutch tries to engage with switch, then the switch and relay are good, and the clutch will need adjusted or replaced
Oct 16, 2013 | Mtd Garden
I have af935 the power takeoff will not turn on at times other times it kick back out would like to know how to adjust it.
Hi and welcome to FixYa, I am Kelly.
All of the PTO functions are controlled by a combination of safety switches.
1. Clutch Brake Pedal switch
2. Seat occupant switch
3. PTO engaged Switch
(Noted this is a 3 cylinder diesel)
Any one of the three can cause the problem your having.
- One of the main reasons this happens is that the clutch often is not properly adjusted. The clutch must be fully to the UP position. You have to crank the engine without starting it to test this. I use a large screwdriver across the starter solenoid terminals so it does not start. If the clutch brake pedal moves more to the up position when cranking the engine then the clutch is not properly adjusted. The clutch must be adjusted so that the clutch pedal is all the way to the top. I.e the variable speed pulley is fully open. After clutch adjustment test the moder deck / PTO.
- Second reason they kick out is that the occupant safety switch (seat switch) is out of adjustment. Stupid things like a small bump cause the deck to shut down if the seat switch is not right. All you do is adjust it so that it is closer to the seat sensing position... One turn of the locking nuts (lower and upper) clockwise will make a world of difference.
As far as the PTO itself there must be at least a 0.020 gap when it is disengaged. If it is larger than that then the gap needs to be adjusted. The PTO clutch on these needs adjusted at regular intervals. I recommend checking the gap every 100 hours. The PTO clutch is probably out of adjustment there are bolts on the PTO clutch that have springs on them if the springs break it goes out of adjustment just replace the springs and tighten everything up. The other thing to look at would be the engaging lever itself.
One more thing is this PTO clutch has a fuse. I can't remember now where the fuse is but I am certain there is a fuse. Find the fuse and make sure that there are not any problems with the fuse holder. (hot, loose, corroded etc.)
Thanks for choosing FixYa,
Kelly
May 10, 2011 | John Deere Garden
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
Blades won't engage when the engage knob is pulled
there is no adjustment drop deck all the way down spray all moving parts with wd40 mash clutch all the way down release quickly several times crank and try
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a Countax K14 ride on mower the cutter deck
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Garden
John Deere Pto Clutch For Stx38 And Stx46 Lawn Mowers Logo
259 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
