Question about Mattel Electronic PICTIONARY MAN¿
Where can I get Pictionary man markers
The marker that came with my pictionary man has worn out. I tried a dry erase marker and it wouldn't come off except with a magic eraser. Are the markers a special kind of marker?
3 Suggested Answers
ipodfreek
  • 64 Answers
SOURCE: WHERE CAN I DOWNLOAD OR
I put it here.
Posted on Jan 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I lost the pictionary man
Yes you can and here is the link:
http://service.mattel.com/instruction_sheets/M1009-0920.pdf
4 page manual.
Happy New Year and Thanks for choosing FixYa,
Kelly
Posted on Jan 01, 2011
What type of markers can i use on pictionary man?
Dry Erase markers only. Not permanent. Expo brand is awesome and they last. Have fun!
Apr 30, 2016 | Mattel Electronic PICTIONARY MAN¿
Tip
Clean difficult marks off your whiteboard
When a message or any marks are left on a whiteboard for longer than 24 hours it becomes very difficult to clean off the board. These marks are difficult but not impossible to get off.
You will need rubbing alcohol and a soft clean cloth. There will be fumes given off by the rubbing alcohol therefore if you are going to be cleaning up a large whiteboard you will want to open a window.
Taking the cloth, apply some rubbing alcohol and rub it on the ink. It is important that you not use a soft cloth because using a brush or abrasive sponge will cause damage to the board.
You might need to apply a little pressure to get really old stains off. If you find that a stain isn't coming off it is possible that it is permanent marker, to get these off you can draw over the marks with a dry erase marker and then wipe it off using a clean cloth that has rubbing alcohol on it.
To avoid getting in these situations, only use dry erase markers and clean the board as soon as you are done with it. Leaving marks on the board will make them harder to get off.
If you are worried about ruining the whiteboard you can always use a whiteboard cleaning solution. For this you just spray the solution on the board, let it sit for five seconds and then wipe it off. The solution will also get rid of any residue left behind by other cleaners that you may have tried to use.
on Feb 10, 2014 | Office Equipment & Supplies
What is a whiteboard?
A whiteboard is a non-electronic variation of the traditional "rewriteable" schoolroom blackboard, but is white instead of black and of a material that can be written on with colored markers (known as dry erase markers). Dry erase markers are easier to erase than the chalk used on a blackboard (which sometimes requires a wet rag for thorough erasing).
Jan 24, 2013 | Office Equipment & Supplies
My intsul disc is sractched so bad that it will not install on to my new computer what do i do now??
Clean off the CD. Run some warm water over it and then rub it with a microfiber cloth.
Rub from the inside edge, straight out to the outside edge.
Do not rub in circles.
Continue this process until the CD is dry.
Pour rubbing alcohol over the CD. Shake the excess off and let it air dry.
When CD is dry, try playing it to make sure that it wasn't simply dirty and not scratched.
Hold the CD in the light and try to determine precisely where the scratch is located.
Scratches will usually be visible.
If you can see the scratch, place a small amount of plain toothpaste
(the type with baking soda works best) and fill in the scratch with it.
Take the microfiber cloth and get it only slightly damp.
Rub the excess toothpaste off by working from the inside edge of the CD to the outside edge.
Repeat this until it is clear.
If you are having a hard time locating the scratch, but rather see several scratches, using your cloth rub a thin layer of Vaseline over the CD.
Gently wipe it off by once again moving from the inside edge to the outside edge of the CD, in straight motion, not in circular motion.
The Vaseline will fill the cracks, allowing the tracks to be read by the laser beam.
Use an original Mr. Clean Magic Eraser.
Lightly dampen it and run it along the CD in straight lines from the inside edge to the outside edge only.
Continue this process until the CD has been completely wiped with the eraser.
The magic erasers contain small microbead particles that can fill the crack
Things You'll Need
Rubbing alcohol
Toothpaste with baking soda
Microfiber cloth
Vaseline
Mr. Clean Magic Eraser can be purchased on Ebay
AU $2.78 +postage
AU $4.67
http://www.ebay.com.au/itm/MR-CLEAN-MAGIC-ERASER-/390187665113?pt=LH_DefaultDomain_0&hash=item5ad8ff46d9
try it once you have your cd cleaned any ready copy and paste it to a folder ready to burn it or do a cd copy
hope this helps
Oct 05, 2012 | Audio Players & Recorders
Chapter markers not playing when they should
I have experienced that markers on unfinished discs are erased and replaced with 5 or 10 minute markers when the disc is finalized.
Sep 15, 2012 | Toshiba Rdxv60
Hi, my pictionary for ds won't read, can you give me tips what should i do
You could try cleaning the contacts on the DS card. You could also try cleaning out the DS card slot with a q-tip. I hope that this helps!
Mar 03, 2011 | THQ Pictionary for DS
I lost the pictionary man travel rules. Can I ge tthem online?
4 page manual.
Kelly
Jan 01, 2011 | Mattel Electronic PICTIONARY MAN¿
Pictionary says disc unreadable and it's brand new. this does this on some games but not all. please help....
Make sure that you are inserting the disc correctly. If this doesn't work, your lens might be dirty, in which case you need to purchase a Wii Lens Cleaner ($10). This will make all your games run smoothly. No freezing or lagging.
Dec 26, 2010 | THQ Pictionary for Nintendo Wii
Mattel Electronic PICTIONARY MAN¿ Logo
140 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
