Question about Grilling
Traeger auger My tailgaters auger will not stop and pause like it is supposed to. It just keeps feeding on the lowest setting. It is feeding like its on med or high. Can not get it into smoke mode.
  • 332 Answers
SOURCE: When I turn my traeger on, the auger turns for
Call Traeger direct. I had the same problem with mine and the sent me a new control unit. Install time 15 minutes fixed the problem
Posted on Mar 07, 2010
Testimonial: "thanks for you help!"
  • 332 Answers
SOURCE: The pellet auger on my traeger doesn't feed pellets
Call Treager direct
They have a great customer service dept and if you have an issue with a motor or control board they are really good about sending replacements
800-372-3437
If this helps please leave a comment
Posted on Mar 30, 2010
  • 34 Answers
SOURCE: How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Posted on Apr 17, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Traeger BBQ070, purchased 4 months ago.The auger
Sorry to read about your problem, I hope this helps you out.
you have a defective auger, you are under warranty. so dont try to make repairs contact Traeger
http://www.traegergrills.com/support/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
  • 4736 Answers
SOURCE: should my traeger be 350 smoke and med it over
Your question was rather confusing, but the generic answer for smoking any type of meat. poultry or fish, is 225 - 250 degrees F. Any hotter, you've gone from smoking to grilling. Smoking any type of food is "a low & slow process."
The adjustment for maintaining a certain temperature with a smoker is by opening or closing the air intake damper(s) Closing the damper(s) slows the intake air flow to the fuel and it burns slower and cooler. Opening the dampers does the opposite.
Hope this helped you. Please let me know.
Posted on Jun 15, 2011
Breaking up solid pettet in auger
Traeger has an FAQ related to this on their website at http://www.traegergrills.com/. Look for it under" why are there no pellets in the firepot?" You may have to remove the augur but Traeger explains how to do it in this FAQ.
Jul 06, 2014 | Traeger Industries BBQ070 All-in-One Grill...
I have an older traeger and it doesnt seem to heat up on high mode. it has 2 fans and both work but one seems to knock now and again. when i cook chicken on high it will take 2 hours to cook.
The Traeger website at http://www.traegergrills.com/ has an FAQ about grills not reaching the appropriate temperature and how to adjust the augur to fix the problem. Here's what they say:
Q. I've been noticing that my grill temperature keeps dropping lower. What is the problem?
A. You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
Hope this helps
Hope this helps
Jun 11, 2014 | Traeger Industries Grilling
On smoke setting my temp goes up over 300 degrees
Traeger suggests realignment of the augur for grills that are not getting hot enough. I wonder if this might be the same solution for grills that are getting too hot.
Here's their solution which I copied from the Traeger website at http://www.traegergrills.com/.
You might want to contact Traeger at their website to verify that this is a solution for overheating. In the above case, the improperly aligned augur was not dropping enough pellets in the firepot. In your case, it sounds like it may be dropping too many. This sounds like a routine maintenance thing that ought to be done periodically anyway.
May 12, 2014 | Traeger Industries Grilling
Traeger bbq problems
This is a common problem if you're trying to cook when its cold outside. Traeger sells insulating blankets for grills that are being used at 35 degrees or less. However, it could be an augur alignment problem that's keeping the augur from dunping enough pellets in the firebox. Here's Traeger's FAQ for that problem.
You probably should contact Traeger customer service at http://www.traegergrillscom to confirm that this is your problem.
Apr 04, 2014 | Traeger Industries BBQ070 All-in-One Grill...
My Traeger (BBQ070) will feed the pellets, but there is no ignition to burn the pellets.
Be sure check the fuse behind the control board when pellets auger in but do not ignite.
Dec 09, 2011 | Traeger Industries BBQ070 All-in-One Grill...
The auger on my 9 yr old grill has stopped and my family is not happy! I do not have a Mr Fix-it husband so am on my own. Any suggestions?
Make sure that there electric power to the auger motor. If it's plugged into an exterior wall outlet, unplug it and plug in another electric device (like a lamp) to make sure that outlet still works. If it doesn't, go to your home's Circuit Breaker Panel and check for a tripped breaker. If you find one that's tripped, reset it and try plugging in the auger motor and turn it on. If it starts working then suddenly stops, it probably tripped the circuit breaker again. That would indicate one of three things: The cord from the auger motor may be bad; the auger motor itself may be shorting out; the circuit breaker may be failing. If it's the receptacle or the circuit breaker, I'd advise you contacting an electrician to have them check and replace it. for the Auger Motor, go to Traeger's website home page and look for Trouble Shooting or Customer Support. Better safe, than sorry.
Hope this helps solve your problem.
Feb 08, 2011 | Traeger Industries BBQ075 All-in-One Grill...
Pellets keep feeding. cant control temp.
Are you trying to grill or smoke? In ether case, once the pellets ignite and the temperature you want has been reached, the switch should be turned to off. That should stop the auger pellet feed.
Also, are you using Traeger Pellets. They are the only one designed for this grill/smoker. If you're using heating pellets for a pellet stove, that also would cause that problem
If you've lost your Owners Manual, here's a link to it in a downloadable and printable pdf format.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ070_Manual.pdf
Hope this helps. Please let me know.
Feb 06, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Grilling Logo
73 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
