Question about Car Audio & Video
Looking for info on how to hook up sub to this amp thunder4160
Have 2 - 3-ways already hooked up,were do i hook up the sub?
  • 221 Answers
Hi, you have two choices for hooking up a sub to the 4160 amp. You can either connect your sub to one of the two available channels, or if the amp supports it, you can bridge channels 3 and 4 to get increased power to your sub. You have a 4 channel amp - channel 1 and 2 go to your 3-way speakers up front, which leaves channel 3 and 4 available for your sub.
Posted on Jul 27, 2013
SOURCE: sony 1200 watt amp
What kind of deck to you have? Sometimes there's a setting for the subwoofer output that has to be turned on. How is the deck hooked up to the amp? Be sure of the normal things: -Make sure the sub is connected in side it's box -Make sure the RCA cables didn't come off the deck -Check every connection! Let me know and be sure to leave feedback or I don't get paid.
Posted on Oct 03, 2007
blueextc3221
  • 15935 Answers
SOURCE: car amp has power but will not push subs
output blown on power supply - repair by tech required.
Posted on Jan 12, 2009
  • 102 Answers
SOURCE: Can i kook up 4ohm dvc sub to a kac-x810d amp?
No, the sub is dual 4ohms...meaning if you parallel the positive speaker terminals and the negative speaker terminals you will have a 2ohm sub. Conversely, if you series the pos and neg you will have an 8ohm sub. if you wirte to just one set of terminals on the sub you will have a 4ohm sub.
Posted on Apr 12, 2009
  • 4 Answers
SOURCE: sony xplode 1000w amp has green light puts out no power to subs
check the speaker, the subs. i had same problem, same reading on volt, its correct as way it should be. if its not the rca plug then it has to be speaker, i replaced the amp and it wasnt that, it was the speakers after all...
Posted on Apr 20, 2009
  • 19 Answers
SOURCE: i have 4/3/2 ch. alpine f-240 amp- i want to hook
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Posted on Dec 27, 2009
How do I hook up subwoofer sony cxs-gt08hp
NO!!NO!!NO!! Dont hook up just a sub to rca outputs. they run at around 2-3 volts and maybe 1 watt. the difference in the settings is for a sub amp(sub) or a amp for mids and highs (amp). the only way you will not need to run an amplifier is if you get a powered subwoofer, as these already have an amp built in.
Dec 24, 2012 | Sony Car Audio & Video
HAVE KIKCER L7 WHEN HOOKED UP TO AMP IT DOESNT DO ANYTHING HOW COME
lets do some diagnosis.. if it's possible, try hooking another known good sub up to the amp and see if that works. if it doesnt, it's an issue with your amp. if it does work though, it's an issue with your sub. or the wiring. if it's a dual voice coil sub, make sure you've got both positives hooked up to positive from the amp, and both negatives hooked up to negative from the amp. if you've accidently got positive from the amp going to positive of one voice coil then to the negative of the other, and the negative from the amp going to the negative of one voice coil then to the positive of the other, the voice coils will be pushing against eachother cancelling eachother's movements out. and this will fry the sub. OR the sub is already fried.
Feb 16, 2010 | Sony XM-2150GSX Car Audio Amplifier
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Send me info how to connect a 4-channel car amp with 2 12-inch subs rear and 2 front 2-way speakers?
plug two subs in to amp in most powerful channel then your speakers in the less powerfull take your positive from your battery and hook it to your amp your ground wire shud just touch a solid piece of metal take your remote wire and hook it to your deck all other wires shud be with your deck need n e thing else holla
Apr 19, 2009 | Car Audio & Video
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Another question for zzedly about the speakers cutting out
So, as I see it, your system is hooked up like so:
  • Ch1 = Left speakers, front and back
  • Ch2 = Right speakers, front and back
  • Ch3 = One sub
  • Ch4 = Other sub
One thing you can try is swapping channels. Swap Ch1 with Ch3 and Ch2 with Ch4. Then see if the issue still occurs on the door speakers or do the subs suddenly cut out at loud volume. If the subs start cutting out, that means the issue is with Ch1 and Ch2. If you haven't already, check the RCA connections to Ch1 and Ch2 as well as the gain for all channels. If the gain isn't already set to about 50%, put it there.
Mar 14, 2008 | Kicker IX404 Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Help ASAP Plaese
Are you saying you connected the sony output jacks to your subs directly without any other amp? Are the sub outputs powered? Or line level? Are the subs powered or direct? need some more info please. and post the Manual here if you can. Thanks
Jun 14, 2006 | Sony CDX-M850MP CD Player
Car Audio & Video Logo
159 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
