Question about Kenmore Elite 30" Freestanding Electric Range w/ Double Ovens -
Error code EO 14 on Kenmore elite double oven model 790.97513100
4 Suggested Answers
fixyourboard
  • 310 Answers
SOURCE: Kenmore Elite oven error code SAb what is this?
I think you have entered "Sabbath Mode" which blanks the display ... check your owners manual to see how to exit this mode.
Posted on Jun 23, 2010
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
SOURCE: kenmore elite 36'' glass top cook top beeps and displays eo 11
so does mine
Posted on Oct 02, 2010
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
May 23, 2015 | Kenmore Elite 30" Slide-In Gas Range White
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Kenmore 629
Could be the lock needs replacing the oven won't self clean if the door lock isn't functioning it's a safety thing so you don't get your face burnt .
Ray
Apr 16, 2014 | Kenmore Cooktops
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
Jun 23, 2010 | Kenmore Elite 44173 30 in. Electric...
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
Kenmore Elite 30" Freestanding Electric Range w/ Double Ovens - Logo
163 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
