Question about Toys
Where can I find Flybar 800 replacement thrusters?
How do I adjust a pogo stick to jump higher
No. You would need a different spring to do it. There is no other spring for it.
Jun 04, 2014 | Flybar Foam Master Pogo Stick - AGES: 9 up...
Axe cp flybar paddles do not return parallel to swashplate after cyclic stick is moved left or right
it should not spin freely, the collars should have a set screw to keep the flybar secure
May 02, 2017 | Rc Helicopter Axe Cp Heli Max Flybar...
My air hogs helix 360 is bobbing front and back how do i fix this?
No this wobble is not caused by the tail motor. i have had 3 that have all done the same thing. The fix is simple. The tail would cause it to go back and forth like it is turning back and forth with rudder. When he says bobbing he is talking about a oval shaped motion that the heli does while hovering. looks like its rocking front to back. tail wag is different and has to do with gyro over sensitivity. To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
Feb 18, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My Airhogs Helix 360 will not hold a stable hover. It continually rocks back and forth without any controller input. This occurs even after a stable hand release. When doing a hand release, the rocking...
vlad that is tail wag. he is not talking about that. To fix: Look at the flybar and check for even flybar paddles (if looking down the flybar make sure one is not angled differently than the other) you can twist them a little to manipulate them. #2 the small extensions connecting the flybar to the links may be bent up or down. Again, looking down the flybar make sure they are pretty level with one another (you can slightly bend them back but be gentle. #3 There is a pin connecting the flybar to the head that goes through. What happens is, after a few bang into things this can start to move out just a fraction of a mm. You will notice that the flybar can move back and forth like it should very easily but there is also a little play rocking it the other way that it is not supposed to go. this amount will be very small but plenty to adversely affect the heli. take a pair of needle nose pliers and carefulle push that pin in just a touch until the flybar tightens enough to stop the movement. Be sure its not too tight so it takes away from the easy movement the flybar is supposed to have. I 100% promise its not the tail motor.
I have a helix 360. after a pretty minor crash landing the flybar is stuck in the forward position, making the helicopter unflyable. what I mean is that as the rotor turns, the flybar is stuck in the...
Probably need a gentle bend back to its original position. Can you look at a friends or a shop one to see exactly what it should look like before a crash? Crashes usually bend something. Good luck.
Feb 13, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My helix 360 wobble back and forth in flight wont stablize.
Jan 17, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
Help! my helicopter keeps wabbling around and it wont fly strait
The wobbling is called "tail wag" and is cause by either a bad tail motor or the speed controller built into the circuit board. Try replacing the tail motor. ~VLAD~
Jan 11, 2011 | Spinmaster Air Hogs Helix 360 Helicopter
My helicopter is off balance when i fly it it wobbles around in the air
Sounds like "Tail Wag" which is caused by either a bad tail motor, or the speed controller built into the circuit board. Try replacing the tail motor. ~VLAD~
My hawkeye heli's flybar hits the wings. So when it goes up it falls back down because of it. How do i fix that?
sounds like the shaft has been jarred loose causeing the fly bar to exceed its limit. return for refund or exchange, or if you feel brave carefully crazy glue the flybar housing to the shaft so that the bar it self still operates but has no left right play in it... worked for one of the 4 i had....
Jan 04, 2011 | Air Hogs Reflex Micro Helicopter
Toys Logo
49 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
