Question about Tascam US-322-USB 2.0 Audio Interface with DSP
How can I get stereo output from synthesizar thru Tascam 322 Interface into computer?
I get stereo sound out of the phone jack of the synthesizer. But when I connect the synth into the Tascam US-322 (left line out to left input / right line out into right input) and record using Audacity, the result is a mono sound.
SOURCE: Problem with the Tascam US-122 audio/midi interface
lol ..
i had the same problem..but its not that big of a deal
just switch it to "mono" on your interface
that should do it!!
Posted on Jan 22, 2008
  • 34 Answers
SOURCE: Tascam us-122
bn ghghfghfhghghghghsf.
Posted on Mar 22, 2008
SOURCE: can't record in stereo
I have a tascam 144 that came with cubase. I am not able to figure out Cubase either. I am a beginner and am trying to record my yamaha electric drum set with it. so far no luck at all.
Posted on Mar 30, 2008
SOURCE: Tascam dp-01fx
Problem solved!! 1 mic and 1 guitar into each input, and make sure you've selected the correct input on MULTI A or B switch...remember set up A first sy on the left input, then set up B on the right input. Obviously, you can only do them 1 at a time.
As regards to your error message (50) it is a possibility that you have to create a new song first then save it at which point you will nam it. The recording has to be longer than 4 seconds though to make a title!!.
Does this help both of you
Regards
saranden
Posted on Oct 10, 2008
  • 189 Answers
SOURCE: Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Posted on Jun 25, 2009
How do i get songs from my computer to my tascam dp 02
you can connect wire from computer head phone jack to Tascam recording jack on back of unit.assign track for song to go to,punch play on computer and record on unit. will record song in stereo.
Jul 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
I just want to use my old tascam 414 as a mixer so i can run 2 pianos and my computer through my 2 monitors - need help in hooking everything up
I would connect the 2 pianos to 1-2 and 3-4 (assuming you want to use the stereo outputs on the pianos.)
The computer I would connect to the stereo input named 5-6. You will need a 1/4" stereo jack here. Just like the one you find on old headphones.
You could also have the pianos in mono, and use channels 1 and 2, and then connect the computer to 3-4.
Connect your monitor speakers to L-R out.
See page 5 in the manual for a diagram: http://www.accessguitar.com/inventory/tascam/porta_414mkii_manual.pdf
Your computer goes where it says "effects" on the diagram.
Hope that helps!
Mar 06, 2011 | Tascam Starter Pack for 4-Track Cassette...
I have a Tascam TM-D1000 digital mixer that has a TDIF output and want to connect this to my computer. Do I need a PCI 822 card or is there another option to connect?
I have a TMD1000 connected to my computer via the RCA ( Red & White) outputs on the mixer to an M-Audio 2496 Sound card in the computer.
also via the Digital out on the mixer to Digital in connector on the card.
I then edit recordings on the computer with Cubase pro.
Nov 28, 2010 | Tascam PCI822 Digital Audio DTRS Interface...
I have an us-122 and i only hear my voice threw one of my spreaker
either the right or left jack are not plugged in or the phone jack is not in all of the way... i have never had that problem... check all of your connections... third... test other speakers (pref small computer speakers)
Feb 28, 2010 | Tascam US-122 USB Audio/MIDI Interface...
TASCAM US-122 OUTPUT, WHAT SPEAKERS TO USE?
You simply need a cable that converts this rca output to a Jack output.
Here's a link I think is right, though to make sure we would need more info about your model of soundcard:
http://www.kabeltje.com/audio-jack-tulp-c-54.html
I hope this helps,
Yannick
Feb 17, 2009 | Tascam US-122 Sound Card
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
TASCAM 144 is not a soundcard, but an audio interface
You are correct, there is no "voice generator" within the Tascam US-144.  It can simply transmit the very primitive note-on note-off type data to a Sound Module or keyboard (like a Roldan SoundCanvas), and then that would generate the actual waveforms.
A SoundCanvas would suit your needs well, as you could run the midi out to this voice generator, and then run the stereo output of that back through the Tascam and into the computer for recording.
Aug 11, 2008 | Tascam US-144 Sound Card
Hellp!
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
If anyone can help me out,please do!
Alternatively you could load your stereo instrumental track into a wav editor, then export each stereo track as a separate mono wav file which you can transfer via usb into you DP-01 and then on you DP-01 import those wav files into two separate tracks which you can pan hard left and hard right so they are in stereo.
Dec 28, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam US-322-USB 2.0 Audio Interface with DSP Logo
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
