Question about Plumbing
Touch sinking fix
Water doesn't flow out of it for some reason. Their is a button that is usually blue but it has turned red. How can I fix it?
    Novelist:
    Champion:
  • 259 Answers
It sounds like you may have a built in filter in the faucet. The red may indicate that it is time to change the filter, but more than likely it is an indicator for low batteries which are located in the cabinet below the sink. Either change the filter, or change the batteries.
Posted on Jan 18, 2014
Why is water is continuously flowing from the detergent drawer, even when the washer is turned off?
i think an inlet valve has a fault or has gone rusty inside becouse its worn
you should get someone in too fix it for you
or
you can tell which valve is faulty
usualy at the back there is a red hot water and a blue cold water
if you have both connected
turn off the red one under the sink and see if the water stops
try the blue next
if it stops then replace the valve
associated with the bad water intake
viola a fixed machine
two connections and two screws
you shouldnt use it just now incase the valve decides to open fully and stay open can reck your home
Dec 17, 2014 | Samsung WF448AAP Front Load Washer
My badger 5xp is leaking drain water from the red reset button?
You have to replace the disposal.
Disposals are sealed units, and cannot be repaired once they rust out.
If water is coming out red reset button, then that is very common point for water to exit the steel canister.
The motor is getting wet.
The electrical wires are getting wet.
This is a shock hazard, and sink and disposal should NOT be touched when switch is ON.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 06, 2012 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Where can I find the water valve shut-off for my kitchen sink
The sink usually doesn't have a shut off of it's own look on the side of your house ,the side closest to the meter & there should be a main water shut off valve for the house.
Jun 06, 2012 | Plumbing
T mobile touch pro 2 doesn't power on.
Take the battery completely out of it and let it sit for about 5 minutes. Then install the battery and see if it will turn on normally.
Don
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
DISPOSAL HUMS BUT CANT FIND RESET BUTTON ON WHITMAN
The problem is not that you tripped the circuit breaker. Problem is that your disposer is jammed.
Over time, food particles may accumulate in the grind chamber and baffle. Here's what to do:
1. Place stopper in sink opening and fill sink halfway with warm water.
2. Mix 1/4 cup baking soda with water. Turn disposer on and remove stopper from sink at same time to wash away loose particles.
If that doesn't help, you have to release the disposer jam.
1. Turn off disposer and water.
2. insert one end of self-service wrenchette into center hole on bottom of disposer. (It's a funny looking slightly "S" curved tool.)
3. Reach into disposer with tongs and remove object(s). Allow disposer motor to cool for 3 - 5 minutes, then lightly push red reset button on disposer bottom. (It maybe indented so almost unoticeable.) If motor remains inoperative, check service panel for tripped circuit breaker or blown fuses.
Oct 28, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The water flow is coming out at about a third of the usual flow. What is wrong? and how to fix this problem?
Try removing the faucet aerator. Turn both hot and cold water on and see if flow is adequate. Clean or replace aerator if that's the problem.
Apr 23, 2011 | Elkay BLH15C Lustertone Self-Rimming...
Hot water flows hard cold water barely flows and I cant shut it completely off I have a single valve price pfister, not sure if I installed it upside down is there a main direction
usually looking at unit hot water supply line is on left and cold line is right side if this is correct one problem can be u mounted unit upside down other is possible need to adjust anti scold remove center handle and will see a red and blue plastic clip lift back red or blue and move till water is balanced the way u want valves are normally shipped in cold position for safety reasons
Oct 18, 2009 | Plumbing
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Plumbing Logo
932 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
