Question about Toto Aquia II Dual Flush Toilet
I have a toto duel Max toilet and the water leaks out of the bowl slowly. By the end of the day, I will have no water. Please help
    Master:
  • 966 Answers
Check flushing mechanism at the bottom of tank to check if it vopens and closes securely. and nothing blocks it.
Posted on Jul 30, 2013
  • 6 Answers
SOURCE: Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Posted on Mar 16, 2009
meBNme
  • 334 Answers
SOURCE: My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
Posted on Aug 20, 2009
smokenic
  • 49 Answers
SOURCE: New Toto toilet continues to trick water
check the water level in your tank if it is filling ,ajust the float in your tank so it stops before going over the overflow. if not your flapper is the culpret
Posted on Sep 20, 2009
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
jeff_drakesr
  • 155 Answers
SOURCE: my toto toilet flapper comes down too fast not
Shorten the chain link so that when handle is pushed down the flapper stands more upright. Dont shorten to much so that it wont seat all the way either. Good Luck and a Great Day. Please rate 4 THUMBS UP if this was helpful.
Posted on Apr 01, 2010
My toto toilet duel flush is leaking from the tank to the bowl what do I need to repair
It may just be a loose bolt, so make sure they're tight first. If not, you just need to replace the rubber ring between to bowl and the tank.
Mar 12, 2017 | Toto Home
Leaking from water tank
Is the water leaking from the tank onto the floor or at the water valve located where it comes in from the wall.
Feb 08, 2013 | Toto Toilet - Elongated Bowl, Dual Max -...
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
No water in tank
Check to make sure the valve that goes from the back of the toilet to the wall is open.
May 31, 2011 | Toto Toilet - Elongated Bowl, Dual Max -...
I cannots top leaking. The toilet is full with water but from time to time it opens the walve to get more water in.
When a fill valve opens up from time to time to let more water in it is because the rubber flapper is not sealing properly and is allowing water to slowly seep out.
Toto Caryles have a 5 year parts warranty so keep this in mind if ti applies. If replacing the flapper doesn't solve the seepage problem then the flush valve (the white assembly the flapper connects to) may have to be replaced.
Be sure to install the new flapper at the exact chain length as the one you removed.
Aug 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toilet bowl gurgles after flushing cycle
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Aug 16, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Toto Drake ADA: Usual rush of water on flushing doesn't happen
Problem solved.  Reason was a totally blocked waste line that resulted in toilet malfunction.  Toilet functions normally now with removal of blockage.
Dec 27, 2008 | Toto Drake ADA Compliant Toilet with...
Toto Aquia II Dual Flush Toilet Logo
174 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
