My Kingston 32GB Datatraveler pendrive is not working on any pc , when i plug nothing shows up , what to do ? how to repair ? please help me if there is any solution for it or should i throw out ?
W7
First, please disconnect all USB devices and then
perform the following steps:
Click "Start" button, type "devmgmt.msc"
(without quotation marks) in the "Search" bar and press "Enter".
Click "Continue" if necessary.
In Device Manager, double click to expand
"Universal Serial Bus controllers", right click on the Host
Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under
"Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will
reinstall all USB controllers automatically.
for xp or earlier
Click start right click on computer select
properties device manager scroll down universal serial bus controllers
you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this
fails to fix the problem
check the USB leads that attach to the motherboard
usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems
to a computer and its parts
Click start click to open on my computer
you should see your usb drive could be E: or something right click select
properties there will be an array of options
select the sharing tab option then
advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have
all 3 boxes ticked full control changes and read in windows 7
Click
start control panel administrative tools computer management disk management
right click on your drive select properties click tools you should see click
check now click start two boxes
automatically
fix files and scan for and attempt recovery of bad sectors place then a tick in
both boxes then select check now start
you
might tick one box then return after its finished the first repair then return
and tick the second box you should not do anything while the chkdsk utility is
in progress any input may damage this drive
then
you restore it to its default status
Right click on usb drive select properties you will
have an array of options
Select the hardware option then select your drive
properties policies
restore defaults
In XP
Right click on your drive select properties then on
customize restore Default in W 7
You might have to alternate doing this repeatedly
until the problem is resolved
Click
start control panel scroll to folder options view place a tick in show hidden
files folders and drives
this may vary depending on your operating system.
https://tails.boum.org/doc/first_steps/usb_reset/windows/index.en.html
Posted on Jul 30, 2013
SOURCE: How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Posted on Jan 07, 2009
SOURCE: Kingston 32gb pendrive complete format
Dear Chandu!
Try formating in safe mode, as well as make sure that all the programs and utilities are stopped before formating it( you Can use Task Manager for that) ,Use an updated anti virus program for scanning it from viruses.
Posted on Jan 17, 2009
SOURCE: DATA INSIDE 32GB KINGSTON PENDRIVE CANT BE RETRIVED
I have worked through this problem. It is a new virus attack. you should get your antivirus updated and then get your drive cleaned. It surely will help you solving your problem.
Posted on Feb 20, 2009
SOURCE: kingston 32gb pendrive
I can solve that u have to format ur usb via mw630 tool
Posted on Feb 26, 2009
SOURCE: my kingston 32gb pendrive not format
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
Posted on Apr 23, 2010
Jul 21, 2014 | Kingston DTIG3/32GB 32GB DataTraveler G3...
Jun 20, 2012 | Kingston DTIG3/32GB 32GB DataTraveler G3...
1. Open Notepad and do not write anything in it. Just go to File > Save as (save it with the name: autorun.inf)
2. Copy the autorun.inf file that you have created in the above step and paste in your "Pen Drives"
3. Remove your pen drive.
After removing the pendrive, re-insert in your PC. Now your anti-virus will not detect any virus in your PC. And Your pendrive is 100% safe to use.
Jun 01, 2011 | Kingston Digital DataTraveler 4000 8 GB...
Nov 27, 2010 | Computers & Internet
Apr 03, 2010 | Kingston Technologies 512MB DataTraveler I...
Feb 20, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Feb 14, 2009 | Kingston Technologies 512MB DataTraveler I...
Jan 17, 2009 | Kingston Technologies 512MB DataTraveler I...
Dec 22, 2008 | Kingston Technologies 512MB DataTraveler I...
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Apr 20, 2018 | Computers & Internet
