Question about Boating
Calibrate humminbird 385 ci
Insrument is off by about 2-3 miles
Why does my fish finder sieze up when i start my boat?
it seizes up because their is a very hi draw on your battery when the motor is turning over, the starter draws so much power from the battery that it drops the voltage down below what the depth finder needs
Aug 11, 2014 | Humminbird 597 Ci Hd Combo Sonar/Gps
Humminbird 798 ci xi HD Combo - While traveling at 32 mph the mph and distance traveled started to flash. I could not get them to work so I restarted the locator and then they were no longer on the...
Do a master reset on the unit. restart and cross your fingers. If this does not resolve the problem you probably have an internal fault with the GPS unit.
Aug 06, 2013 | Humminbird 798ci SI Combo GPS Receiver
I have a Stanley IntelliSensor Pro. It's worked fine for a couple of months. Now it won't calibrate - it just flashes quickly calibrating, and alternatively flashing the centre (bullseye) ci
I hate to tell you this as you are an electrician but often it is best to look for the simple solution. My Stanley IntelliSensor Pro was doing the same thing here is the answer:
CHANGE THE BATTERY
Apr 26, 2012 | Cars & Trucks
My dept finder reads gives me the wrong depth. Is there a way to calibrate this. I doint know the modle off hand. It is the one that gives you two side views and stright dowm. It has the temp. and speed.
If your depth is off because of where your transducer is located, calibration can be done through the menu by adding or subtracting a foot or two.  In your never to be read manual are all the instructions necessary.  If you are off by more than a foot or 2, chances are your transducer is bad.
http://www.humminbird.com/support/ProductManuals.aspx should allow you to download the manual for free and even step you through some troubleshooting.
Aug 09, 2011 | Humminbird Sport & Outdoor - Others
I need user instruction manual
If you visit this url there is a download button that gives you the manual for this GPS device.
http://www.retrevo.com/support/Humminbird-12-GPS-manual/id/540bh447/t/2/
I will also post a direct link to the button itself.
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=201775fbd475319d607a772a6cc14dea&modelid=540447&q=Humminbird+Matrix+12
Cheers!
May 02, 2011 | Humminbird Matrix 12 Fishing System
My Humminbird 788 ci screen clutters up and gives crazy depth readings when the trolling motor (mk terrpva80# w/ ipilot and built in td w/mkr-us2-8 cable) is set on mid to high speed settings. It does...
One thing you might try is restoring the defaults in your unit. One other thing is go into the menu under the sonar tab and adjust your Noise Filter. You may have some type of interference going on. You can call our customer service department and they will trouble shoot it for you. Our number is 800-633-1468.
Joby from Humminbird.
Jan 01, 2011 | Humminbird 787c2 Combo GPS Receiver
Mamual
hello there:
here is a few links that have the manual that you can download for free
  1. Humminbird 595C Manuals, Support and Troubleshooting - Fishfinder GPS Free download of Humminbird Fishfinder 595C User Manual. ... Humminbird Fishfinder 595C GPS. Need a manual? HUMMINBIRD 595C MANUAL ...www.retrevo.com/support/Humminbird-595C-GPS-manual/id/540ag515/t/2 - 96k - Cached
  2. Humminbird GPS Manual and Support Information: User Manuals: Retrevo ... largest collection of user guides and manuals on the web. ... Humminbird Fishfinder 595C. Operations Manual. Humminbird HDR 400G. User Guide. Humminbird HDR 400I ...www.retrevo.com/samples/Humminbird-GPS-manuals.html - Cached
Sep 16, 2009 | Humminbird 595c GPS Receiver
Is it possible to make my Humminbird 787c2 to show METRIC unit instead of IMPERIAL?
hi
Did u bought Humminbird 787c2+GPS or just Humminbird 787c2 ?
If u bought Humminbird 787c2+GPS i like to know, do the built in GPS UniMAP work in australia ? i bought one myself. Thanks.
Mar 27, 2007 | Humminbird 787c2 GPS Receiver
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
