Question about Denon S-302 Theater System
RE: BLOWN SUB / PROTECTIVE LIGHT ACTIVATED / TROUBLESHOOTING GUIDE NEEDED PLS
MY PREVIOUS Q: WAS REFERRING TO THE DENON S-301... NOT A CAR AMPLIFIER...!!
2 Suggested Answers
  • 483 Answers
SOURCE: Denon DRA-397 zone 2
zone 2 is just for an extra set of speakers in another location, your sub is not attatched to that zone
Posted on May 21, 2013
When I power my Denon AVR-3311ci on, it only comes on for a second then shuts off completely. No blinking red light and nothing on the display. I can hear a relay on the power board clicking. Any ideas?...
Greetings
have you checked the speaker cables ?
please do
Usually the Denon system has a problem with power regulators
if u have any knowledge in electronics i can guide u to repair it
if not .. u have to send it to service.
check for fuses if blown
power regulators mostly are damaged
and or power output transistor damaged
Good luck From Audio-adviser.com
Feb 17, 2015 | Denon AVR-3313CI
How to reset denon s 301receiver?
Instructions
  1. How to Reset Denon Receivers
    • 1 Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
    • 2 Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
    • 3 Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
    • 4 The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Sep 09, 2014 | Toshiba DVR40 Multi System DVD Recorder...
Subwoofer not working
There may be an internal fuse that's blown. I'd take it to a repair facility and have them check it. Could also have a bad connection inside. Good luck!
Feb 15, 2014 | Denon DHT-1513BA Home Theater System
Denon DP-7F subweights
I don't know what you are referring to as sub weights. Everything you need is already on the tonearm.First you have to balance the tonearm, then you adjust for stylus pressure and anti-skating. For more information, please my website at audioserviceclinic.com. Thank you.
Nov 23, 2013 | Denon DP-47F Turntable
How to fix blown sub (replace fuses etc)...? stop protective light illuminitating?
The first thing to try is to disconnect the sub and all speakers from the amp's output block. The only things that you need connected to the amp are the 12V power, the ground wire, and the remote wire to turn it on. If the protection light comes on with only these three wires connected - your amp has been damaged internally and will either need to be repaired or replaced.
Jul 27, 2013 | Car Audio & Video
Protection light is activated since i installed extra speakers- nothing works now
What do you mean by extra speakers? If you hooked more than one speaker up to one output, you probably blew the amp.
Jul 18, 2013 | Denon S-301
Tuning speaker system denon avr 2400
You need to check on the operation of your receiver regarding the use of the subwoofer output line. If it does not satisfy you, better get a better receiver or A/V control pre-amp system with lots of features in the subwoofer circuitry. Google (internet) might help you with your specific model.
Sep 24, 2008 | Denon AVR-2400 Receiver
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
I just brought mine to the shop for the same reason. I thought it was something big but it was just a bad fuse. It wasn't blown so when i checked it, I didn't think anything of. If you're using an AGU fuse, try and remove the fuse and touch the two ends of your power wire together and if it's the fuse it should cut on
Mar 18, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Denon S-302 Theater System Logo
26 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
