Question about Toshiba Satellite P25-S5093 Notebook
Drive hard install p25s5093 satellite toshiba disk
Hard drive missing dls. only boot to BIOS. Have receovery disk but DVD never worked. Can I use flash drive for recovery disk. If yes, how do you format flash drive
3 Suggested Answers
SOURCE: Recovery Disc will not load OS on HD
laptop panasonic toughbook bios password pro
Posted on Apr 07, 2010
technolust
  • 340 Answers
SOURCE: need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Posted on Jun 06, 2012
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 06, 2012 | Toshiba Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Hello.. I need some help. I am using toshiba satellite a1O system unit..my laptop was fyn till nw..all of a sudden windows doesnt load..when i turn the power on, the toshiba logo is shown..then black...
Hello
First thing you do is to see what hard disc installed in your laptop. You can check that by checking it in your bios system. To check in your bios system first turn off your computer then press delete while your laptop is booting up. Then you will see if there is a hard disk detected in your lap top if there is a detected hard drive this means you have a problem in your windows installed in your lap top.
There is also a reason why those message appear if the first boot of your laptop is the CD/DVD ROM. Check you CD/DVD ROM if there a CD inside this may the first on to read while the laptop booting up. Remove the cd inside your CD/DVD ROM. Then restart your laptop. Check your hard disk connector it may have some loose contact thats why your laptop did not recognize the hard disc.
Hope this can help keep on touch with fixya. Hope to hear some testimonial from you. . .
Aug 12, 2011 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Replaced hard drive now computer wont boot
If you have a restore CD/DVD that came with your Toshiba, you may have to use it to reformat your hard drive and do a fresh installation. You may have a bad sector or cluster and the boot file is located on it. Try this and check the bios for the setting of your hard disk too. Try starting the system on safe mode by pressing F8 at boot time.
Mar 21, 2009 | Toshiba Satellite® A135-S4467 PC Notebook
System Restore
It seems that your computer is not booting from DVD-ROM drive nor hard disk, but is trying to establish a network setup of the operating system.
You have to go to BIOS settings and correct these preferences by making your hard disk the first boot device. Of course that would be a solution if you have operating system installed on it. If there is no operating system installed on the hard disk, you will need to install it. In this case, your first boo device would DVD-ROM or CD-ROM, whichever available.
Jan 16, 2009 | Toshiba Satellite M35X-S349 Notebook
Hard drive not recognized
format your hard drive completly with this http://www.killdisk.com/downloadfree.htm
you have to create a boot cd with this software.
once formated reinstall your OS.
But if bios does not see this HD it it's also mean that is dead.
Jan 01, 2009 | Toshiba Satellite 1400-S151 Notebook
Toshiba Satellite L25-S119 No boot
reset bios to default try installing fresh system
Jan 10, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite P25-S5093 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
