Question about Echo 452vl 452 guide plates
ECHO 452VL NOT OILING CHAIN
No oil to chain from auto oiler, manual oiler OK. Oil port to bar clear. Oil pipe from oil tank OK (get bubbles in oil tank when air blown in through pipe). No strainer at tank end of pipe. Oil knob on max flow. How to remove assembly below knob to check if OK? (Hex nut under knob unscrews to end of thread then just turns and won't lift out). What actually provides motion to pump oil? Regards Len
  • Echo Master
  • 1,807 Answers
Sounds like you have a blocked oil pump. With the flow regulator fully open and no cage filter on the end of the oil intake hose its probably pulled through dirt and blocked the pump.
Posted on Jul 27, 2013
Testimonial: "I don't think this the problem, as I removed the oil filter to see if it passed oil, and it did. I left it off just to see if it made any difference, but no good."
4 Suggested Answers
fphandyworks
  • 56 Answers
SOURCE: Excessive chain oil coming from oil tank onto the chain.
change the oil cap put a new one on the problem should go away.
Posted on Jan 03, 2009
dontbother10
  • 2220 Answers
SOURCE: echo 302 not oiling chain
Your IPL can be found here (there are 6, 4 of them 302Ses):
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
The IPL is not to detailed (page 8 item 9). Please post back (below) with any difficulties you encounter. I am just nosy. LOL TIA and Good luck. HTH
Lou
Posted on Feb 13, 2010
  • 10865 Answers
SOURCE: Echo 310 oiler not
Hello sq. Add one tablespoon of kerosene to the oil reservoir. this will thin out the oil a wee bit and then it should flow properly.
Posted on May 01, 2011
Oil is not getting to the chain with a stihl 012av chainsaw.
I'm almost sure you have to remove the oil tank and then the oiler
Nov 26, 2014 | Stihl Garden
Echo cs 3450 oiler does pump oil to chain bar, leaks along side case
not familiar with that model but check that the oil passage from the pump to the bar is clear and not broken or cracked
Feb 19, 2013 | Garden
Echo cs302 chain oiler not working
after you have cleared all the obvious stuff aka; bar hole, oil outlet, etc, look inside the oil tank to find the oil pipe and screen, if they are intact and not clogged the "O" rings on the adjuster are bad. If not clean the little screen and replace the oil pickup tube, yes they are still avalible. It's a bit tricky but can be done through the oil fill cap hole.
Jan 21, 2013 | Garden
Husqavarna rancher not oiling. I removed the chain and bar and cleared out ports on bar and still not oiling. I adjusted oil flow screw, but it didn't help. Someone said to remove the oiler, but...
Husky has pretty good exploded view diagrams on their website. I would try there to see if you can figure out how it gets removed.
Here is their helpful website:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
good luck.
Aug 26, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 | Garden
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 345 bar oiler
Remove the bar and chain. Start the engine and observe the oil delivery port in the side of the engine case. At a fairly fast speed, the oil should ooze out of the port. If little or nothing, check the pump, lines, and in-tank filter. If ok, clean the bar drive-end holes of sawdust and dirt, especially the small passages that go from the large holes out to the chain groove. Clean the entire groove and the outer end sprocket. Reassemble and test the oiling by running the bar tip at speed in front of a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Apr 09, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
New chain installed, cut for 1/2 hour, chain now sags well below
Place a piece of white paper on the ground
Start your saw and point the tip of the bar at the paper, this will allow you to see if it is oiling or not
I am assuming that we are dealing with a newer saw and not an old manual oiler
Blowing air back through the oil ports in to the oil tank ( with the cap removed and oil tank drained) should help clean out whatever is plugging it.
Once cleared run a bit of diesel through the oil tank, drain it and refill with clean fresh oil
I never use old oil in my saws for just this reason
Hope this helps
Scott
Mar 17, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 141 will not oil and when i had it serviced they replaced the oiler and it did not solve the problem.
Remove the chain and bar assembly. Start engine--should pump oil from oiler port where the bar fits on the engine side. If oil comes out, then possibly the bar-oiling passage in the bar itself is plugged with dirt or sawdust--blow clean with compressed air. If no oil comes out from the port, check the pickup tube inside the oil tank. Drain the oil into something and fish the pickup tube end out with a hooked wire. Replace if collapsed, cracked, or loose.
Jul 04, 2009 | Husqvarna Chain Saw 20" Bar
Echo 452vl 452 guide plates Logo
198 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
