Question about Car Audio & Video
How to fix blown sub (replace fuses etc)...? stop protective light illuminitating?
WE'VE BLOWN THE SUB FORCING THE PROTECTIVE LIGHT TO BECOME ILLUMINATE... WHAT OTHER THAN FUSES COULD BE THE ISSUE? WHERE DO WE LOCATE FUSES AND/OR OTHER POSSIBLE ISSUE/S (ANY SUGGESTIONS)??? REALLY APPRECIATE ANY ASSISTANCE..
  • 221 Answers
The first thing to try is to disconnect the sub and all speakers from the amp's output block. The only things that you need connected to the amp are the 12V power, the ground wire, and the remote wire to turn it on. If the protection light comes on with only these three wires connected - your amp has been damaged internally and will either need to be repaired or replaced.
Posted on Jul 27, 2013
StuartB
  • 807 Answers
SOURCE: blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Posted on Mar 17, 2008
  • 631 Answers
SOURCE: Protection light won't stop blinking/ Subs don't work
The amp probably has shorted output transistors to eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Posted on Oct 07, 2008
cuvilldj
  • 14 Answers
SOURCE: INFINITY AMP PROTECTION LIGHT FLASHING
Overload maybe. If the amp is run at an improper impedence, the amp will shut down. If you are "CLIPPING" speakers / subwoofers the light will blink to indicate a hard clip . Example: 4ohm/2ohm stable amp with 4 ohm subs wired at 1 ohm.
Posted on Jan 29, 2009
HitWizard
  • 67 Answers
SOURCE: INFINITY AMP PROTECTION LIGHT FLASHING FOR 5 SECONDS
I have an Infinity amp as well, and I was having the same issue for a time. The amp is protecting itself from some sort of overload. It could be the Ohms load on the sub, but I would guess not. Make sure your low pass filter is set to LP and not HP or Flat. Then check the RMS on your subs and match that to the Amp RMS. Once I did all that I found that everything worked fine, for a time. It started doing this again, and I checked the fuse and it was blown badly. It seems that the fuse setup on some of these Infinity amps is not as good as one would hope, because the charge was bridging the gap and frying out my fuses. It was like a spark would jump from one side of the fuse to the other without travelling the fuse itself, and this was causing my protect issues. I pulled the fuse, got a new one of the same rating, but I placed the fuse in with a little piece of rubber in between the 2 contacts, and then connected to the fuse block. I have not had problems since.
Posted on Feb 02, 2009
  • 14 Answers
SOURCE: i think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Posted on May 01, 2009
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Kicker dx 500.1 keeps ruining my subs
if your sub isnt blown, i'd follow your own idea and look for a bad wiring connections, also what kind of head unit do u have? check the settings on ur head unit to see if there is a seperate setting for your amp/subs if it does have one, make sure it is set properly
if it does not have a setting like above, check the rca cable from the radio to tthe amp, and make sure that the rca cable is plugged in to " input instead of the output
Jan 15, 2013 | Kicker 2010/10 Dx500.1 Car Audio Monoblock...
No air from vents, cant hear motor working ford focus
Hi Victoria,
Your car's electrical components, like those in your home; are protected by fuses and / or circuit breakers.
You car has two fuse boxes. One is located under the hood (in the engine compartment) and the other in in the passenger compartment. Some popular locations are under the dashboard, in the dashboard behind a removable cover, under a seat, etc. Consult your owner's manual to determine the location for your car.
Once you have located the fuse block, you will need to determine which fuse is associated with the heater / AC fan, as there are dozens of fuses in the fuse block. The protective cover usually has a directory of fuse size, locations and function. If yours lacks such a directory - your manual will have it. It is not unusual for several directory pages in the manual, as the manual may cover several versions of the Ford Focus. If this is the case with yours, be sure to look at the page(s) for your version Ford Focus.
Once you've located the suspect fuse, remove the fuse with a tool that may be provided on the cover, etc. or other tool. The fuses are made of hard plastic, and are generally pretty durable - but can break if crushed in a tool. After removal, look for the shiny metal inside the plastic. It should appear unbroken along its entire length. If it is broken, it has opened. The plastic should not have any black areas inside - if so, it indicates the fuse has blown. Either of the conditions indicates that the fuse should be replaced. Replace the fuse with a new one. Fuses are color coded by amperage, be sure to use the same color fuse or fuse value. Do not increase or reduce the fuse value.
After changing the fuse, test the fan to see if it works. If it does, close everything up & discard the old fuse - you're done. Otherwise, double check the fuses to be sure you've changed the right fuse, etc. You may need to have the car service professionally if the fan motor or control has failed, etc.
I hope this helps & good luck!
Oct 19, 2012 | Cars & Trucks
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
Aug 18, 2008 | JBL GTO75.4 Car Audio Amplifier
No power
Disconnect the sub or speakers and turn on the amp, see what happens. If the amp turn on without the protection light, then your sub is blown. Also check to make sure ALL your fuses are good including the one under the hood. If you have a meter, test the fuse for continuity. The problem can also be a bad ground.
Aug 19, 2007 | Kicker KX150.2 Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Protect light flashing/ticking
this problem sound like you have too low of power going to your amp, test your battery and make sure its putting out enough power for at least the mininum amount of power that your amp requires, you can find that information in your manual or sometimes they post it on the amp itself. i hope this info helps
Oct 08, 2006 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
