Question about Maytag MSD2436GR Side by Side Refrigerator
Rangemaster ice maker
The ice tray turns out before the water has frozen resulting in water running down through the freezing compartment
smilemaker
  • 790 Answers
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
Posted on Dec 29, 2007
  • 1314 Answers
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Posted on Jan 02, 2008
mohammed387
  • 1952 Answers
SOURCE: Refrigerator MAYTAG MSD2454GRQ: Ice maker not
compressor changed.............. epoxy coating lifting from the aluminum tray, and under the bubbled up coating was green and brown slime.put the new complete ice maker tray and control unit in, purged the water supply system and replaced the filter, cleaned out the ice bin and started making ice again.
Posted on Oct 29, 2008
ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a problem with my freezer, it has water
Your defrost drain line is clogged and frozen over with ice.
Turn off the fridge. Remove the bottom freezer drawer. Take a hair dryer and thaw the drain hole at the back bottom section of the freezer. After you defrost the drain line pour 1/4 cup bleach into the drain hole.
Posted on Jun 28, 2009
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
Ice Maker WR30X0327 Freezing Over I have an
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
Mar 03, 2017 | Refrigerators
My ice maker overflows and runs down the left side of the freezer and freezes on the wall as well as cubes have been know to fall out. There is a possibility that the ice maker does not cut off when full....
Another potential issue that I have found is that you may have very strong water pressure coming into the fridge, which might make the water jump and splash out of the tray. Perhaps turning down the water pressure somehow might be an easy (and cheap) solution?
Jun 28, 2012 | LG LRSC26925 Side by Side Refrigerator
Ice maker not making ice
Not sure what model you have, but recommend you check to see if there's not a cube stuck in the dispersal unit. If not, then check plastic water supply tube in the back of the icemaker, sometimes they freeze solid and won't let water flow into the ice tray. I've had to use a hair dryer to defrost it if the freezer temp gets too low. Also, sometimes the ice maker inadvertently lets too much water enter the trays and it slightly overflows, which results in the freezing of the gears and paddles of the maker and you simply have to chip away the excess ice that overflowed the trays. If none of the above are the case, make sure you still have a solid water supply to the back of the unit, if the line runs outside of the heated portion of your home, it could have frozen outside of the fridge. Hope this helps.
JB
Mar 03, 2011 | Maytag Refrigerators
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
The tube freezes over where water comes in to fill the ice tray
You may have a related problem. If the freezer compartment isn't sealing off it will have excess moisture inside eventually making excess ice build up on the water inlet tube on the ice maker. Otherwise the water inlet valve is not closing completely and a little bit of water is building up and freezing.
Dec 26, 2007 | GE GSS20IEP Side by Side Refrigerator
Maytag MSD2436GR Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
