If you remove oven door this will make it easier to undo lens cover
let it warm up then cool down to a point where you can comfortably put your hand in the oven,wear a suitable glove a gardening one is ideal you should be able to remove it once carbon deposits are loosened by heat be sure to turn it correct way when its upside down most of my customers turn it the wrong way tightening it up!
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
