How to enable disabled boot menu items - Computers & Internet
  • Terry Sheekey
    Terry Sheekey Jul 27, 2013
    i go to boot boot menu set the order i require to boot but they are all disabled cant enable them
    Top Expert:
  • 12,223 Answers
You must restart the computer Hold the keys CTRL +f2 or esc and enter the BIOS setup, go to the tab, appearing the selection of BOOT and enable or disable, that option that you wanted.
God bless you
Posted on Jul 27, 2013
My boot menu key is disabled how to enable it
when the computer boots up use either F2 , F4 , F6, or F8 sometimes you need to press both F4 and F6 together and once in the boot menu enable the options under boot menu and restart the pc
Feb 16, 2014 | ZT Group Cisnet PC Desktop
Laptop screen display -when laptop is started screen message reads prepairing atoatic repair. then message dissappears and only mouse icon is visible.
On boot up tap the F8 key until you get a menu. Select Safe mode. If it boots disable all startup processes and services by clicking Start, run and type msconfig. Reboot, if it boots the you can enable one item and reboot until it no longer works and you will have your culprit.
May 16, 2013 | Compaq Presario CQ58-a10NR 15.6" Windows 7...
I have downloaded the MapiLab Mail Merge Toolkit to use with MS Word and Publisher. However, only Word displays the option to use it, not Publisher. I need to know how to enable it for Publisher.
The "MAPILab" folder is created in the "Start" menu. It contains the folders of all installed add-ins the way it is shown below in the menu:
Open the help of some installed add-in and see the "Introduction" or "Working with the program" sections to find the description on what control items it adds to the Microsoft Outlook toolbar and menu and under what conditions these items become visible and available.
If there are no described items in the Microsoft Outlook interface, make sure the add-in is loaded (look at the article "How is it possible that I cannot enable an add-in? What are "disabled items"?).
Hope this helps!
Sep 13, 2011 | MAPILab Mail Merge Toolkit
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
My computer takes very long to boot
Slow Booting is mainly due to startup items. I would recommend you to disable unnecessary startup items which will surely improves your computer booting speed.
You can do that by following below mentioned steps
Step1: Click on start and then click on Run.
Step 2: Type MS Config and hit ENTER.
Step 3: Click on Startup tab.
Step 4: Click on Disable all then click on apply and then Click on OK.
Step 5: Your system will be prompted for a reboot. Go ahead and restart it.
Step 6: As soon as the system is backup you would get syste configuration utility screen where in you should Check "Don't show this message again".
Step 7: You are all set. Try rebooting again and the booting speed will be lot better.
Note: If you want you keep one or two start up items enable which can be done manually. However disabling start up items will not hamper your system in any way its just that those will not load during boot up. It will still work with out any problem.
If the complete system in slow then disabling start up items does not solve the problem.
Good Luck
Nov 30, 2010 | Computers & Internet
My computer is very slow booting
Good Luck
Nov 16, 2010 | Computers & Internet
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Sep 08, 2010 | ASUS P5KPL-AM SE Motherboard
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
How to disable onboard graphic card on asus psrd1-vm mother board
There should be a menu item in your BIOS to Enable/Disable On-board video.
Not sure what key on your computer selects the BIOS Setup Utility. Watch when it begins booting. It will show it for a few seconds. Maybe F2?
Jan 15, 2009 | Microsoft Windows XP Professional With...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
