Question about Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece)
Disassemble Logitech X-540 sattelite
The metal cover makes noises while playing higher frequencies. So i want to take it away but i cant find any screws and don't want to use brute force. Anyone knows a way to take them apart? ty
  • 84 Answers
SOURCE: Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Posted on Feb 11, 2008
SOURCE: no sound
are u using vista? cause this is def a driver issue...could be the update Driver they released messed up things or the driver needs a updated from windows...it wouild help if u posted the driver version and Operating system u are using.
Posted on Mar 30, 2008
  • 3 Answers
SOURCE: How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Posted on Feb 01, 2009
ViscamTech
  • 528 Answers
SOURCE: logitech x 540
Following is a diagram showing how to connect the speakers. a1d5e61.jpg This was taken from the logitech x-540 user manual. You can download the manual from http://safemanuals.com/user-guide-instructions-owner-manual/LOGITECH/X-540-_M
Posted on Aug 14, 2009
zzedly
  • 300 Answers
SOURCE: Connecting Logitech X-540 speaker system
Most newer TVs have a set of audio output jacks (red/white). All you need is an adapter like this to plug into those audio output jacks, then plug the speakers into the adapter and you'll be good!
-=Zzed=-
Posted on Nov 05, 2009
Change the bulb in my Lloytron model L880. I can't work out how I get access to remove it. I have tried to turn the metal surround of the bulb using the small metal pole on that surround but i
You do need to remove the bulb cover directly. Get your fingers around both edges of the curved glass cover and just pull it straight out towards you. You need to use brute force because it's stiff. The glass cover comes away WITH the metal clips at either end. I've done this about 3 times now and every time I forget how. Hopefully next time I'll remember!
Dec 22, 2014 | Cars & Trucks
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Aug 23, 2011 | Nintendo Wii Console
When I first start my truck I can hear a loud rattling sound coming from the back. Hear this sound also when I am in idle. Don't notice it when I pick up speed.
Check to see if one of your brackets holding the exhaust pipe has come loose. That'll make a rattling sound - especially if it towards the end by the tailpipe. When you're accelerating - more air is forced thru your exhaust at a faster rate, so it's not moving as much as when you're sitting still and the truck is just at an idle with less air/exhaust moving thru the tailpipe. If it's only making the noise while the truck is stationary & the noise stops one the truck is moving - that pretty much rules out anything to do withe the drive-train or suspension. You are sure the noise is from the back & not coming from under the hood? If under the hood - check your oil level ASAP.
Jul 29, 2011 | 2004 Ford Ranger
The tray on player won't stay closed therefore I can't play a dvd.HELP
It sounds like there is something inside the dvd player, that isn't supposed to be there, that is keeping the tray from retracting fully. Try unplugging the unit and gently turning it upside down and giving it a little shake. Not too hard. This might jar the item loose, you will hear it knocking around. If you do knock something loose turn the unit so the front is pointing up and let the foreign object fall to the back of the unit where it hopefully won't interfere with the operation of the mechanisms inside. If you don't hear something come loose, remove the screws on the bottom, sides and back of the unit to remove the top cover. Make sure you have unplugged the power before you do this. take a look and see if you can find something jammed in the track or the gears for the tray. If you do gently remove the item with your fingers or a pair of needle nose pliers. Once removed replace the cover and away you go. If there is nothing blocking the tray and the mechanism, you probably have a gear system to close the tray. At some point someone must have pulled fairly hard on the tray causing the gear teeth to jump, check and make sure they aren't damaged or stripped. You are going to have to them either remove one of the gears (or pull it up so it can turn without turning any other gears) push the tray back into the fully closed position and replace the gear. Once you have done this you will want to test to make sure the tray will function properly. Place the top cover back on, but don't secure it with the holding screws in case you need to open it back up again, plug the unit in and test the tray. If it works unplug it and secure all the screws for the cover and away you go. Otherwise you are going to have to play with the gears till it is back in the proper starting position. If your hearing some strange noises and its not working, then the gears are probably badly stripped. You can contact the manufacturer and see if they can sell you some spare parts or direct you to someone who can replace it. Though at this point simply replacing the unit may be less expensive.
Jul 26, 2011 | Zenith XBV243 DVD Player/VCR
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
Open Questions:
See all Logitech X-540 Multimedia Surround Sound Speaker Questions
Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece) Logo
131 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
