Question about Garden
Florabest chainsaw fbks4614
FKS2200B1 won't start
    Sergeant:
  • 458 Answers
The most common problem these days is old fuel. if the fuel is 2 or more months old dump it all out and start with fresh fuel.
Posted on Apr 11, 2014
4 Suggested Answers
  • 2239 Answers
SOURCE: have a electric florabest chainsaw
There will be a tank to tank chain oil to lubricate the cutting chain as it rotates around the bar, DO NOT PUT WATER IN IT .
Posted on Jun 09, 2011
hunter19_46m
  • 7482 Answers
SOURCE: chainsaw won't/ starting diffcultiy .would
Hi jeffery webb... Make sure you are getting spark at the spark plug, to do this: Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug. You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark. If you are getting a nice blue spark then skip A below and go to B. A...If you do not get a nice blue spark then you may need to replace the electronic module. Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting. B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area. Then follow the procedure below: ********************************************************************** Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible. Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel. Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT. Note:Before you disassemble the carburetor: Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor. Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces. That way you will know which way it goes back together when you reassemble it. Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor. Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank. Check you fuel line condition after a while they will degrade and need replacement. Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws . When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a picture for later reference. Normally the big line will be the line the fuel filter is connected to inside of the tank. The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb. Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking. If the chainsaw is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank. The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc. When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages. Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable. Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages. Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages. Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from. When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws. But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position. Be sure to mark the turns down on a piece of paper. That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started. Note: The little spring inside of the carburetor goes under the float arm. That is where your fuel inlet needle/float valve is located...on the arm at the end. Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation. The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position. Once you have your carburetor cleaned/rebuilt that should solve your problem. Please take time to rate me thumbs up
Posted on Sep 29, 2011
SOURCE: Chainsaw won't start. Replaced carburetor, fuel lines, fuel filter, ignition module, spark plug. Using new gas and oil. Has good spark but won't pop.
try priming it mite work lol
Posted on Mar 29, 2012
Florabest fks 2200 b1.advise which kind of oil required
The oil is for the lubrication of the chain. You can purchase chainsaw chain oil in a hardware store, Home Depot, Lowes, etc. 30 weight engine oil can be used, but the chain oil has special additives for the oil to adhere to the chain, so I would recommend using the chain oil. It can be purchase in one gallon size.
May 26, 2014 | Computers & Internet
I need a manual
When it comes to chainsaws, check out STIHL.CA wicked website for a begginer chainsaw operator
Feb 02, 2014 | McCulloch Original Partner Florabest...
Florabest chainsaw
Try nearest smallengine repairshop
Oct 30, 2013 | Garden
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
Have a electric florabest chainsaw it wont start no power does it need water in it as there is a slot for something like oil or water but it ie empty
Jun 09, 2011 | Garden
Instruction book for Grizzly florabest FSG130 chainsaw grinder
Hi Fixya........contacted ....info@grizzly-gmbh.de and they sent a copy of the instrution book by e-mail........problem solved, thanks...Mike
Sep 04, 2009 | Grizzly Saws
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
