Question about Boating
1990 yamaha 650 super jet
After riding for 30min. I turn off and then it wont start(very faint or no spark). Then the nest day it start right up. ride for 30min. and then wont start. any suggestion. thanks george
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,190 Answers
If your coil ht leads are carbon inside get an after market one with copper wire inside ht's as they break down easy ! ive had this lots !
Posted on Jul 10, 2014
My yamaha v-star classic 650 wiil not start after i stop riding when it sit for a few hours. it turns over but will not crank
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Help My Star 650 Wont Start
V650 won start in 650 Star Tech Forum
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
OEM parts for Yamaha
Yamaha XVS650 Service Manual
Jul 06, 2014 | Yamaha XVS 650 Dragstar Classic...
Yamaha blaster 2001
No fuel or no spark. Quick test: spray some starter fluid into air intake and try to start it. If it runs and then dies, you've got spark but no fuel. If the bike quit with no prior symptoms, check spark plug wire not knocked loose, fuel filter clogged. (You do have gas, right?)
May 20, 2014 | Sport & Outdoor - Others
Triumph Daytona 650 turns over but wont start
Do you have spark to the plugs? Do you have fuel getting to the cylinders?
May 17, 2017 | Triumph Daytona 650 Motorcycles
Canadian bike 1991 Yamaha fj1200,50,000kms. engine sputtering at all speeds. Bike can be ridden (barely). No throtle response when cranked full from cruising speed. Fuel tank was drained & checked for...
Chances are there is a water build up in the carb float bowls. The water comes from condensation in the gas tank. Try draining the carbs. Another possibility is carburetor main jets partially plugged up. You must clean the carbs if plugged jets are found to be the problem. Please rate my answer. Thanks. tombones49_152.gif
Jun 01, 2011 | Yamaha FJR 1300 Motorcycles
I have a yamaha pw50, it runs slow when cold &
Most likely a combination of sparkplug heat range (type of plug) and jetting, needle or air mixture settings in the carburetor. Assuming good condition of air filter and operation of the choke plunger. Are you using the correct octane fuel and fuel/oil ratio? Give the plug a clean and emery the spark contacts, set gap at 0.7mm., ideally take the plug to a Yammy dealer and check for correct range for your bike in the area where you ride.
Best to have a range of spare clean plugs handy for wet or hot days etc.
The jetting maybe dirty or wrong size too. In the meantime move the throttle needle clip down one notch. Refer to the site below for a diagram of the carburetor parts. Cheers.
http://www.cmsnl.com/yamaha-pw50r-2003_model11163/partslist/A-09.html
May 10, 2010 | 1981 Yamaha XJ 650
2003 yamaha rx1 snowmobile my engine light is
Go to this site and get yourself a manual, it should contain the information you require plus a lot more:
http://www.yamaha-motor.com/sport/myyamaha/prompt/L3Nwb3J0L3NlcnZpY2Uvdmlld21hbnVhbHMvdmlld21hbnVhbHMuYXNweD9scz1zcG9ydA==/Owners%20Manual/starthere.aspx
Feb 10, 2010 | 2003 Yamaha YZF-R1
Yamaha XV17 Runs For A Minute - Then Dies
The dealer is not interested.
The bike is set up very lean to meet emissions standards. Any of them will benefit from larger jets. It's probably running too lean.
Jun 06, 2009 | 2007 Yamaha Road Star Silverado
V-Star Tune Up
the stuff it came with is just fine. your bike shop where you buy the oil from will give you what they deem best for your bike, oil weights depend on where you are and ride. a K&N airfilter will help it breath better than the standard one but it wont do much for the performance. i have jardine pipes on mine i believe it was re-jetted when the previous owner installed them but i run a standard air cleaner and all is fine.
Mar 31, 2009 | 2004 Yamaha V Star Classic
1981 Yamaha xj750rh that is hard to start
your idle/primary(pilot jet) circuit is blocked.Clean the carbs or have them professionally cleaned and put the starting fluid away.
Mar 22, 2009 | 1981 Yamaha XJ 650
Boating Logo
67 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
