Question about Toshiba Computers & Internet
Laptop motherboard short
Hi,am a electronics engineer, my laptop is a damage for the mortarboard laptop Toshiba satellite
  • 3,799 Answers
As you are an Electronics Engineer, You should be able to fix it without telling us what is wrong with it. But, we need to know what is wrong with it to be able to give any advice.
Posted on Jul 27, 2013
5 Suggested Answers
ghoff1
  • 167 Answers
SOURCE: TOSHIBA LAPTOP MOTHERBOARD
notebook mainboards are very expensive! mine was nearly 400.00 bucks,unless you buy used, i did the first time-the onboard sound was broke. so i should have replaced the whole thing. the cost of new notebooks have fallen alot lower. you may consider this. good luck!
Posted on Jan 21, 2009
ailia
  • 175 Answers
SOURCE: Need to get a replacement motherboard for toshiba satellite P-105-S
Hi Dear. From Laptop Repairing Workshop.
Posted on Apr 14, 2009
  • 11 Answers
SOURCE: toshiba satellite A200-27R what motherboard do i need?
Try replacing the fan in it the reason a computer usally goes of is due to this. In the bios sometimes the fan gives a fail safe causing the laptop to go off. Couple of questions though did the laptop heat up alot in the past. If it did you might try buying another laptop mother board. If not this is a less costly adventure than replacing the motherboard.
Posted on Feb 15, 2010
bronk50
  • 27725 Answers
SOURCE: My Laptop is a Toshiba
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these drives are working also it could be a dirty
graphics card you might have remove the graphics card and clean the socket hope this helps
Posted on Jun 08, 2011
Need a new motherboard and I do not know its name and specs
Hi.
If you need a motherboard for the Toshiba Satellite Pro L300 then please click on the link below for an idea of how much a motherboard will cost. You can search for the laptop motherboard using the model number.
http://cgi.ebay.co.uk/TOSHIBA-SATELLITE-PRO-L300-21F--MOTHERBOARD-V000138330_W0QQitemZ320701576368QQcmdZViewItem
Regards.
Jun 07, 2011 | Toshiba Satellite Pro L300 Notebook
My laptop is a Toshiba Satellite L305 model an di gave my laptop in one of the service center they told me that the power section IC is damaged and couldnt find a replacement.what am i supposed.change the...
If you cannot find the replacement for the damaged ic, i will advice you get rid of the motherboard and get a new motherboard for system in other to keep you moving. though it may not what it but it will save you lot of time and stress.
Take care.
Nov 19, 2010 | Toshiba Satellite L305-S5907 Laptop
What motherboards fit a toshiba l505d
V000185540
Laptop Motherboard: MAIN BOARD; RS880MC $268.00
V000185210
Laptop Motherboard: MAIN BOARD, RS780MC 2 $437.50
V000185220
Laptop Motherboard: MAIN BOARD, RS780MN 3 $308.00
http://www.sparepartswarehouse.com/Toshiba,Satellite,L505D,Laptop,System-Boards.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2010 | Toshiba Satellite L505D-S5963, L505D-S5965...
How to clean the fan on a toshiba satellite
If you do not want to tear the system down, just power the laptop down, remove the battery, push the power button for 10 seconds to bleed off the power . Now go and get some compressed air used to clean electronics,you can get it in cans at an office supply company. Using short bursts, blow air in the laptops ventilation grills, using short bursts will keep condensation from blowing out and onto the laptop and also keeps the fan from free spinning and damaging itself. Blow air in all the grills several times over, that mosts the dust and hair back and forth and works it out of the grills, fins and fan blades.
Nov 26, 2009 | Computers & Internet
Satellite ac connecting port damage how do i fix this problem
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
dissasembly instructions,you need to take out motherboard and take a look do you able to fix or need to exchange ac port
Jun 14, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Laptop keyboard problem
When you have a problem like this, you need a new keyboard. The keyboards on a laptop are more fragile than full-sized keyboards, but remember that they are just electronic parts. Fragile circuits can be damaged by misuse (including accidentally spilling liquids). Also, they can fail (just like any electronic part) for no apparent reason.
My suggestion--get a new keyboard. They really aren't all that hard to replace.
Apr 26, 2009 | Toshiba Portege 3110CT (P000278510)...
Flashing Toshiba satellite 1800-S204
Hi
You query did not give any clues abt the PC/Motherboard and its BIOS revision.
That said if the PC/BIOS will not "see" the HDD then its is unlikely a cause of a virus.
Some old motherboards can't recognise a HDD if its size is more than 137GB. Some older motherboard also require than you set the HDD jumper correctly (Master or Slave).
At this stage, i am assuming the HDD in question is PATA or IDE (Old Spec). If the HDD is SATA (New Spec), then you will need a SATA port to connect the HDD. Ensure not to use both "old" molex power connector and "newer" SATA power connector together.
If the HDD is SATAII but the SATA spec for your motherboard is SATAI (initial spec), some motherboards and SATAII drives require that you jumper the HDD to allow it to work at the lower SATA speed.
If none of the above points apply try upgrading your system BIOS of the latest version. Also review the mortarboard's manual for more info.
Regards
Mike
Mar 23, 2008 | Toshiba Satellite 1805-S204 Notebook
Need new / 2nd hand Toshiba satellite laptop motherboard
Hi timlondonuk,
I don't know if you've ever replaced the motherboard in a laptop, but it can be a serious chore - even damaging to the LCD connector and other devices if you're not careful. Oftentimes the cost of a replacement board is 50-75% of the cost of a new laptop, so you might consider that venue.
If you provide a model number we can help you find prices for the board.
Ben
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
