Question about Exercise & Fitness
How to align treadmill running belt (TM1390)
Where can I find a manual for a U Style Sport treadmill, so I can align the running belt (TM1390).
    Top Expert:
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Jul 27, 2013
2 Suggested Answers
SOURCE: I have a trimline 3550 treadmill, that I have
hi email nautalis in america they are the manufaturers
Posted on Dec 18, 2010
How to replace treadmill running belt
First, you have to loosen the belt using the adjusting screws near the back of the belt assembly. Then you have to take the side moldings off.
Once the belt is totally exposed, you can take the belt off. Reverse the procedure to tighten the belt and align it
Aug 07, 2012 | FreeMotion treadmill t7.5
Runs jurky
1)You must shure the motor has level, use some one.use the washer according with the new motor.
2) Tight very well with wrench.
3) Alignment very well the drive belt, not much tension
4) Lube the deck belt with the instruction manual.
5) Lube the rollers bearing very well.
6) Try to run the software calibration for diagnose, and troubleshooting
God bless you
May 09, 2012 | Life Fitness 95Ti Treadmill 95 Ti
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
My xt2700 steelflex treadmill shows err1 code what is the problem amnd how do i rectify it
I an having a STEELFLEX 2700 Treadmill.
In the ELEVATION display its showing "Err7" and the running belt is elevated.Pleas kindly help me to rectify this problem.
My user manual also lost,if someone know the online manual please share the link.
Dilantha.
Mar 10, 2011 | Sport & Outdoor - Others
How do I fix a problem with the belt slipping?
hi there
it could be 2 things of this problem
1 walking belt slips easy ti fix
1th step; put treadmill in speed of 4 mph and step on side and try with one leg to stop it (be carefull) if you see walking belt stops with align key give more tension from the back of treadmill rear rollers by turning both bolts clockwise same degree with small turns till stops
if it does not help it is probably drive belt
you need give more tension on motor by using 9/16 wrenches
Nov 22, 2010 | Proform Sport 1000 Folding Treadmill...
Running mat keeps moving to the left
It looks like you will physically have to inspect the treadmill form under the motor shroud, front roller, frame and to the end where the belt tension bolts are. To see if their anything bent or misalign, this will take some time with good lighting and a extra pair of eyes. You will even have to start the treadmill and watch the entire sequence closely until you see whats happening with traveling running belt. This what I would do Good Luck!!
Jul 18, 2010 | Treadmill Doctor Image 800Q Treadmill Rear...
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Prosport1000 -- belt slips as I begin to run or walk. Motor works fine and belt can reach max speed if I am not on it. Seems like I need to tighten the belt but I have lost all paperwork and manuals.
I have just had the same problem with my Proform 775. The pulley that drives the belt roller has shifted off of the splines. If yours is making a stripping sound this is likely the problem. This is a poor design since the two pulleys (motor and drive roller) do not align properly. I pried the pulley back into place and now it works although the drive belt is now at a slight angle between the pulleys. I am sure the pulley will not remain in alignment for long so I intend to glue it in some manor. I think a good low viscosity thread locker like Locktite 271 might prolong the fix or perhaps liquid super glue. The treadmill is long out of warranty and I have heard online that Proform's support is rather poor. The worst that can happen is I will have to replace the pulley but since a misalignment is the problem (poor quality control) it would likely happen again. By the way, although my unit is about 6 years old, a forced move had it in storage for most of that time. I doubt if the unit has 10 hours of actual use...
Apr 15, 2009 | Proform Sport 1000 Folding Treadmill...
I-run treadmill belt does not run
Maybe check the troubleshooting section of your manual. If you don t have one, check here.
Feb 20, 2009 | Reebok New York Giants Eli Manning Jersey
Exercise & Fitness Logo
95 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
