Question about Coffee Makers & Espresso Machines
Schaerer verismo 701
It says select beverage probe steam and the steamer wont work, how do i get the steamer to work?
JohnnyBeans
  • 223 Answers
SOURCE: Steamer does not work
Your steam wand is probably clogged with milk. Remove the panarello outside and stick a paper clip up the tube. Then try to run water out of the steam wand.
Hope this helps!
johnny
Posted on Oct 12, 2007
  • 2039 Answers
SOURCE: Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Posted on Jan 19, 2008
coffeefixer
  • 53 Answers
SOURCE: I need a User Manual
leave me an email adress (just leave out the @ symbol so bots wont send you spam) and i will send you a pdf of a diferent model thats basically the same, verismo is starbucks i believe. or ask what you need to know and i can prolly tell you what you need to do.
Posted on Sep 01, 2011
yeaandrew
  • 38 Answers
SOURCE: schaerer ambiente display saying" selection locked
the machine seriel number and or cust, number are missing you need a " service card or the machine " save data card "
Posted on Dec 09, 2011
yeaandrew
  • 38 Answers
SOURCE: machine saying select beverage heating steam
Machines steam boiler below set point maybe hi limit tripped... bad relay.
Posted on Dec 21, 2011
My shaerer machine (ambiente) is giving error, selection locked, heating steam. Need help. Thanks.
This is quite common on steam boiler when the level probe is not reached within a specific period of time. Reason is due to limescale buildup which restricts water flow...
You need to remove and descale the fill pipe to the steam boiler. If its very badly blocked, you can drill out the blockage with a 7/8mm drill bit and then leave it soak in descaling solution until its clear and you can blow through it. Also you will find a small restrictor between fittings somewhere back from the fill pipe (between the fill pipe and the fill valve). This is a small disc shape with a 0.8mm bore in the centre, you'll need to check that this is clear also, they are notorious for blocking up due to small size. You can clear this using some very fine wire or if you have the Schaerer expander baffle pen. Be careful not to lose this restrictor when loosening the brass fittings as it is extremely difficult to find if you drop it into the machine. Good luck
Dec 29, 2012 | Schaerer Siena Espresso Machine
Machine saying select beverage heating steam
Oct 01, 2011 | Schaerer Siena Espresso Machine
I need a User Manual for the Verismo 701 espresso
Aug 31, 2011 | Coffee Makers & Espresso Machines
Just had our schaerer ambiente-1 espresso machine worked on by a certified shop (visions in seattle) yesterday and today it is still putting out water with the steam. please help! --of course visions is...
First You need to check the inlet water valve, I think the plunger is not working (sealing) properly and 2nd. Check the water level probe make sure is clean. If you don't feel comfortable doing this take it to a pro.
Nov 20, 2010 | Schaerer Siena Espresso Machine
My shaerer expresso machine (ambiente) is giving error, level steam probe, when this happens it will not steam. This problem does not happen all the time and can be cleared by shuting machine off then...
"level steam probe" occurs when it takes more than two minutes to fill the water in the steam boiler. The easiest solution is low water pressure to the machine. Does it have a water filter? replacing it will probably help. Other problems could be the fill valve is not opening fully and or scaled water lines going to the steam boiler. The first thing I would do is activate the hot water tap and look at the pressure. If the water is coming out slow then I know its a restriction to the machine.
Nov 10, 2010 | Schaerer Siena Espresso Machine
My display says select beverage heating steam. I can pour shots of espresso but no steam or hot water will dispense
Heating Steam The steam boiler has fallen below set point... could be tripped hi -limit .. steam relay faulty
Oct 06, 2010 | Schaerer Siena Espresso Machine
The high temp light keeps coming on and the steamer wont work...
Your water probes are probably grounded to the metal insulation. Stick a piece of paper/plastic between the probe and insulation. or buy the boots that cover the tips of the probes. What is happening is the probes use water as a ground and tells the element contact it is full of water when actually its not. So it is over heating.
Dec 18, 2009 | RTO Groen Adi Foodservice Pressure Gauge
Verismo 801
milk gets sucked into the boiler when the boiler rapidly cools and creates a vacume while your steaming milk. this can be caused by water inlet problem involing the level probe inlet valve or level board. there is also an anti syphon valve that is built into the overpressure relief valve that could be malfunctioning.
Dec 16, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
616 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
