Question about RCA Televison & Video
My rca tv # RLC3210 flickers in and out when I turn it on.
After I unplug it for 5 minutes it works fine for a while,then it happens again after a few days.
  • 68 Answers
SOURCE: Picture Would Come In and Out, Now Not at All
It seems as though from your description it is just the brightness changing. The Cathode Ray Tube has three electron guns at the back end. These are for green, blue, and red. Each gun has a cathode and a grid. Nearly all control the brightness by having the grids tied to a variable voltage. And nearly all control the colour and luminance by an amplifier connected to each cathode. As you do not say the colours change the the amlifiers are OK. I would suggest the voltage to the grids ( or cathodes in some), is unstable due to a bad connection or a dry joint, or a faulty resistor in that part of the circuit. Very old sets without remote control used a potentiometer to vary the brightness. A voltmeter is all that is needed. When the picture goes off try holding the increase brightness for some time, to see if it reappears.
Posted on Nov 05, 2006
  • 1694 Answers
SOURCE: Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Posted on Jan 15, 2008
mjap
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
freetek
  • 5568 Answers
SOURCE: JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Posted on Aug 23, 2008
  • 899 Answers
SOURCE: RCA 24V414T KEEPS TURNING OFF
it could be a ghost but most likely a bad solder connection , crystal(controls the eprom)(menu chip) , or the eprom chip itself will need to be replaced
Posted on Dec 01, 2008
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Tv turns off after it gets hot
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Geno
Mar 17, 2008 | RCA P52937 52" Rear Projection Television
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
