Question about SINGER 7470 Sewing Machine
Bobin I bought a new foot pedle fixed it all up,when I tryed to use it there was nothing happening with the bobin
  • David Snook Jul 27, 2013
    when will I get an answer
My singer machine 2263 is leaving long loops under the cloth.I have tried every thing but nothing works, can you help?
Be sure to use a brand new needle.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot--this releases the tension disk so the thread will seat properly. Rethread the upper thread, making sure the path is correct.
Set the upper tension to the midway point (this is the standard starting point, but may need to be tweaked for your particular machine).
Now, retest your machine.
Oct 10, 2016 | Singer Sewing Machines
Singer electric sewing machine 2 01-2 know it didn't work no electricity going in to sewing machine.Is there away I check the power cord and how do you put together the foot pedal
for workshop manuals go google and type in --workshop manual for singer sewing machine 2 01-2-- and download the pdf version page
take the power lead and foot control to a sewing machine repair shop ( anyone) and have it tested
Oct 07, 2015 | Singer Sewing Machines
WHERE CAN I FIND THE SHUTTLE HOOK FOR MY LS2125
try these sites--you may have to email them about the part
sewingpartsonline.com
sew4less.com
sewvacdoctor.com
a1sewingmachines.com
May 08, 2012 | Brother LS-2125 Mechanical Sewing Machine
I have a Singer Sewing Machine #9444. There is no electrical getting to my machine since the light doesn't work and the foot pedal doesn't work after I turn on the machine
Try replacing the light bulb or rerouting the wire so it won't be affected by the light bulb or the foot pedle. Becarefull though because if you rerout the the wireing in the foot pedle you're taking away the off/on swich so it'll stay on. You may want to open up the foot pedle and see if there is anything loose, not conected or broken. The pedal is used as an on/off swich so it may just be stuck in the off position and not making contact when you press down on it so it won't turn on.
If you can't fined a blulb for it by the way you can disconect the socket where you screw it in and install a new one. Make sure the new one will fit in the same hole though. Then it should be easy finding a bulb for it. PLEASE MAKE SURE THE MACHINE IS DISCONECTED BEFOR YOU DO ANY OF THESE THINGS. Good luck!
Sep 30, 2011 | Sewing Machines
I have a Bernina 830, bought in 1978. When I depress the foot pedal, nothing happens. Power is on. Do I need a new pedal?
I've just fixed this problem by replacingthe main capacitor in the foot pedal. I have a Bernina 830. I needed a soldering iron, and I had to buy the right capacitor, but it fixed this exact problem. Btw, a few months ago this problem initially appeared (on my machine) as an issue where the speed was either zero, or full speed). After a white it wouldn't work at all.
Jul 23, 2010 | Bernina Sewing Machines
I reloaded my bobin and began to sew. The thread
Sometimes it may look like the bobbin is the problem, when it is actually the machine was threaded with the presser foot down.
Refer to the manual for your machine and recheck the direction the thread is be feeding from the bobbin and that it is going through the proper guide(s).
Always thread a sewing machine with the presser foot up.
When threaded with the foot down, the tension is closed and the thread cannot enter. When you sew, the stitches are loose and loopy.
Feb 24, 2010 | Baby Lock Sewing Machines
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
My machine is locking and apparently tangling up inside of the bobin case
You also need to adjust the pressure foot on the top of the machine. This regulates how much pressure is put on the fabric and the feed. Sounds like it is wrong somehow-maybe you need more pressure. Check the pressure adjustment is screwed in properly if it is this type which unscrews.The pressure adjuster Im reffering to is generally a silver colour and looks a bit like a basic tyre pressure guage or pressure cooker valve-it just got a cuple of lines on it and sits on the top left of the machine above the needle bar. The other thing which could cause problems is the bobbin tension-make sure it is running thru smoothly but not too loose.
Sep 06, 2006 | Singer 3343 Mechanical Sewing Machine
SINGER 7470 Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
