How do you remove DVD player from a primera visia 04
DVD player is stuck needs to be greased
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
Open the case ,take the belt out and clean it, lube the gears with oil and all is well.and replace the Belt, if necessary. See if the motor is functioning or replace/repair.How do you remove DVD player from a primera visia  - e8238b4a-ada9-4637-ad0d-fecf1b15e580.jpgd9446467-0b62-4082-a342-dda8fb313e7d.jpg
Posted on Jul 27, 2013
Cd player not working in 2003 nissan primera
There is not one in it is just the mechanism is bad to the lfter is out of place needs service you can try to open the radio your self if yuo think you can do it but if not let some one do it. Or get another one
Feb 28, 2013 | Cars & Trucks
Samsung v8500 dvd stuck
i can understand is this trays is stuck. see the steps and fix it.God bless you.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 03, 2012 | Samsung DVD-V8500 DVD Player/VCR
I have a dvdr3380 player/recorder that when i want to eject disc shows blocked i tap top and it ejects.no problem feeding disc into machine or anything else.can you help.? also can i buy new dvdr3380...
The problem of your unit is the mechanical assembly. To resolve this problem, applying a small amount of grease in the sliding bracket can resolve the problem but be sure not to put grease in the pulley. In order to do this you should remove the cover of your dvd, then you can see the dvd rock remove the screw holding the dvd rock so you can pull out the whole assembly, but be very careful because you may damage the flex cable if you already remove the assembly try to look at the bottom and you can see the railings then you can apply grease. Note be sure to unplug unit before removing the cover. Good day and best regards.
Aug 08, 2011 | Philips DVDR3380/05 DVD Recorder
How to reset service reminder nissen primera 04
for most maxima's .. hold the trip counter in when you turn on the ignition .. a few models have a little rubber cork that you remove .. that exposes a push button ..
Aug 11, 2010 | 2004 Nissan Maxima
My Nissan Primera 2006 car CD changer/player has stuck. CD's will not eject or play
I have 2002 primera & my cd is stuck it wont come make clicking noise any tips please???
Jun 11, 2010 | Car Audio & Video
My clarion CD player in my Nissan Primera P12 2004 will not eject the discs can this be rectified and would it be expensive.
Hi.
Check first that it is not a single disk stuck inside.
Try pressing repeatedly the eject button on the on dash player while at the same time you start the stereo.
If that does not work you can try disconnecting the car battery to reset the unit, and then attempt again the procedure above.
Remember that you may be asked stereo code after disconnecting battery, have it ready.
If still no luck, then the unit must be removed from the dash to be taken apart, so to remove the stuck disk.
In that case the repair may require replacement of CD drive unit or front panel. When disk does not exject repair done from a local technician may be expensive. Usually better replacing the whole stereo unit.
Regards.
PS: Here the procedure above illustrated in detail. The procedure is described for home DVD players, but it is the same on any optical unit, including in-dash stereo. Naturally , since the unit is an in-car system, you do not have power cord, but you will need to disconnect battery to reset the system: player system won't eject disk.
Mar 16, 2010 | Clarion Car Audio & Video
Hi im changigng my break shoes on my fait barvo but the weel drum is stuck
The problem is the worn shoes have eaten a groove into the drum that they can't slide out of. You need to remove the rubber plug in the back of the wheel and using a break adjusting tool you need to loosen the brake shoes so they retract far enough that the wheel can slide over them to remove it.
Oct 31, 2009 | Primera Technology Bravo (Refurbished)...
Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
Jul 06, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
New remote won't work
get a new remote related to ur dvd player
Nov 15, 2007 | Yahoo Diamond Vision DVDC803-04 DVD Player
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
