Nikkai a99hr Disc tray keeps opening and closing all the time
    Top Expert:
  • 12,223 Answers
Please do this:
Open the case ,take the belt out and clean it, lube the gears with oil and all is well. and replace the Belt, if necessary. See if the motor is functioning or replace/repair.
See the image attached.
Posted on Jul 27, 2013
USB EXTERNAL HARD DRIVE
What format has the drive been formatted in? NTFS or FAT? If it is NTFS it won't work, NTFS is the default format of most modern OS. You need to back up the data and re-format the drive to FAT format and copy the files back on to it.
Mar 09, 2012 | Computers & Internet
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
Bought the A99HR Nikkai DVD player and recently the sound does not work anymore. Picture and everything else is working alright.
I had the same problem when I switched over to a HDMI cable. It's the sound settings. I had to switch my audio setup in the settings menu to PCM for HDMI and also choose only SPDIF / RAW or PCM.
Jun 13, 2011 | Audio Players & Recorders
I have an RC100H that keeps opening the DVD/CD tray as if it does not read the disc. Even if I have no disc in it the tray opns and stops. The only way to keep the DVD Tray closed it to hit the close...
eject belt propably worn out, does not close lid proper - so ejects back. change of belt solves problem.
Thanks for using FixYa - a 4 THUMBS UP rating is appreciated for answering your FREE question.
Feb 21, 2011 | LG RC199H DVD Recorder/VCR
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Tray closed, but keeps saying tray open
You are having tray sticking problems, you can solve this temporarily by keeping a disc in the tray at all times, even when the console is off or you can give the console a gentle pat close to the front part where the disc tray is, not advisable though because the 360 already has SMD dry joint problems, do this occasionally, try and remove dust also around the grooves under the disc tray, hope this helps
Oct 25, 2010 | Microsoft Xbox 360 Console
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
Can't play mp4?
You could try a piece of software called mp4cam2avi. It turns a .mp4 file into an xvid/divx .avi file, without actually needing to recode the data, so the quality is just the same!
http://sourceforge.net/projects/mp4cam2avi/
(If you enjoyed this solution and want to do me a favour - can you confirm if your Nikkai A99HR device works okay with external hard-drives? :)
Dec 08, 2009 | Televison & Video
change the motor charge belt
Apr 03, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
