E-01 ERROR MESSAGE - Computers & Internet
    Brigadier General:
  • 3,400 Answers
Moore information.
Posted on Jul 27, 2013
  • 3,799 Answers
Great
Error message "Err 01" on Sony IC BX700
are the power cells identical in every way to the old cells? Any variation can be a problem. Evidently the cells are in correctly or you would not get any message; so this may be related to a circuit board issue. A continuity test would locate the source, and if you do not have test equipment; take it to a camera shop for service.
Apr 15, 2014 | JVC Video Cameras
Precor error code 1
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on Precor Error Code 01
Aug 18, 2013 | Precor 9.21 Treadmill
Error code 1 and 3 on my Precor 9.21s treadmill?
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
SHARP AR C150 COPIER-ERROR MESSAGE H4-01
H means heat, you have a bad fuser.
Jan 28, 2010 | Sharp AR-C150 Copier
I'm getting an error message of E:91:01. I still
E:91:01 is a flash unit error, probably meaning your flash is inoperative .
Try settings, main menu, setup, initialise.
If this does not work, then new flash module required.
Sep 06, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Error message 80 01
The error indicates that the controller detects paper that is smaller than letter size in width.
There may also be a problem with either the rear sensor or the main controller board.
I hope it is just the paper.
Hope this helps.
Apr 07, 2009 | Brother IntelliFax-2820 Laser Fax
Help Toshiba E-Studio 162 Copier error
how can I reset the Toshiba estusio162 without calling for maintenance
Sep 03, 2008 | Toshiba e-Studio162 Copier
System error (-01) message on Nokia 7610
These phones use Symbian and not windows mobile. This error is related to Symbian not being able to control your mobile web and messaging features. Contact your dealer and have the phone reprogrammed. If you have info on it, purchase the data cable kit BEFORE you let anyone touch your phone. Otherwise the phone supports a chip you can use for that purpose. There is also a warranty you might need to check on. Nokia generally has 1 year warranties.
Apr 12, 2008 | Nokia 7610
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
