Question about Dishwashers
How do I reset flashing lights on Hotpoint sdl510 slimline
I have an american style hotpoint fridge freezer MSZ902DF which has had a water filter change as blue light on but despite following process the light has now turned to orange. Can anyone advise what we...
Refrigerator - Water Filter Indicator Light Will Not Shut Off After you change the filter the RESET WATER FILTER must be pressed and held until the red light goes off.
Note: If you do not hold the pad in, the light will stay on. Also, if you hold the pad in for a long period of time, the light will go off and then come back on.
If this does not turn the light off, having it checked by a service technician is recommended
Here is a list of refrigerator manufacturers and how to reset the filter change indicator light:
Amana- Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire- Press and Hold the Reset Button Until the Indicator Light Flashes.
GE General Electric- Press and Hold the Reset Button for around 8 Seconds.
HotPoint- Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air- Press and Hold The Water and Lock Buttons until the Water Filter light flashes.
Kitchen Aid- Press and Release the Light Button 5 times Quickly.
Maytag- Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung- Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool- Press and Release the Light Button 5 times Quickly.
Mar 04, 2015 | Hotpoint Refrigerators
Hotpoint wma58 stopped spinning
unplug it for a hour plug back in see if it resets it self
Apr 05, 2014 | Hotpoint WMA58 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
