Question about Home
How to change the flapper in a toilet bowl - Home
    Master:
  • 966 Answers
Flapper is a rubber device that blocks and releases water and is conrolled by chain attached to the handle. Make sure you have correct new flapper. The old one removes easily. Unattach chain. REconnect new flapper, the chain and test flush.
Posted on Jul 30, 2013
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
kachbibi1
  • 979 Answers
SOURCE: Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: Toto toilet Power Gravity intermittently running
I suggest that you replace the cap with the new seal, it sounds as tho the valve is not shutting off and the bowl fill tube continues to run. Have you adjusted the water level to 3/4 of an inch below the overflow tube. If not, try that.
Posted on Mar 16, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
snap101
  • 117 Answers
SOURCE: Toilet Bowl Water Level Slowly Drops
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Posted on Aug 01, 2009
Fix a running toilet
Faulty flapper sealing. After a flush, the flapper does not seat correctly or completely allowing water to run into the bowl.
Jun 08, 2014 | Home
My toilet keeps running. I tried to adjust the float with a phillips but that did not work. There is slight leaking into the chamber over the top.
If there is a continual leak in to the toilet bowl you will likely need to replace the flush valve or the toilet flapper.
As a first step try try cleaning the sealing surface of the flush valve to se if the flapper will seat and make a seal.
If this does not work and the flapper is visibly detioriated and breaking down shut off the water supply, remove the toilet flapper and visit your local plumbing supply store to purchase a suitable replacement. Install the new flapper, turn on water supply.
These illustrated instruictions may also assist:
http://www.danco.com/HowTo/How-To-Replace-a-Toilet-Flapper
Although less likely, if the sealing surface of the flush valve is damaged or detioriated proceed with replacement of the flush valve. Again turn off water supply and follow the instructions set out here:
http://www.danco.com/HowTo/How-To-Replace-a-Flush-Valve
If there is not a leak in to the toilet bowl and the water flow does not shut off completely, then water is flowing through the fill valve and the overflow pipe and you may need to adjust the float and float rod to allow clsoure of the fill valve. See here:
http://www.danco.com/HowTo/How-To-Replace-a-Float-and-Float-Rod
Mar 09, 2011 | Kohler Cimarron 2-PC Elongated Toilet with...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
When I flush the toilet, water fills the bowl. After about 30 minutes, the water drains from the bowl completely.
Attached to the Flushvalve is a rubber stopper commonly called a flapper. If the flapper is worn this would cause the problem. Also sometimes the chain that attaches the flapper to the handle gets caught and the flapper sdoes not seat right. Check this, if it is clear and not obstructed try repalcing the flapper.
Feb 02, 2011 | Jacuzzi Home
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
Refill water doesnt stopkeeps running
could be that the flapper is not seating properly and lets the toilet tank slowly drain into the bowl..
clean flapper and drain to toilet in tank and verify for proper seating.
if it still runs, my opinion would be to change flapper.. (if new enough, then under warranty)
Aug 02, 2010 | Caroma Home
Water disappears to below the bowl inlet and stop.
adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Nov 17, 2009 | American Standard Cadet 3 Right Height...
After flushing a newly installed toilet, the water will not remain in the toilet bowl but no leaks are present
this sounds like a leaking flapper.although you may not see a leak, this is always the problem.a leaking flapper can be replaced,just becauce the toilet is new does not mean that it may not have defective parts.i would check the flapper first then the fill valve.this will most likely fix your problem.good luck with your project.
Sep 29, 2009 | Home
Home Logo
55 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
