Question about Ryobi Airgrip Laser Level
Lazerpro 16" replace battery?
16" alumium sprit level
2 Suggested Answers
SOURCE: I have a 16 inch Lazerpro level. How do I change
The on/off button unscrews. Batteries are under this button.
Posted on Jan 21, 2011
Ultra HYDRA MP3 player has frozen blue screen with egg timer symbol
TRY CLEANING USB SOCKET WITH PETROL OR SPRIT.DISCONNECT BATTERY FOR A WHILE CONNECT AND TRY AGAIN.
Feb 03, 2011 | Ultra Products Hyrda MP3 Player
My 1100 honda shadow sprit 2002 will not stay running if i have a jump pack it stays running bt as soon as i take the pack off it dies i belive it is the stator
The battery probably has a dead cell and is pulling down your electrical system with it. Start it and disconnect the battery first and then the jump pack and see if it stays running. If it doesn't, then it's the stator. Good luck.
Apr 19, 2010 | 2002 Honda VT 1100 C Shadow Spirit
The on/off switch (handle) does not work. How can I get it fixed?
As many others have noted, the orange switch lever pivots on a plastic pin which breaks off within two years of normal use. I found a 3/16" steel rod at my local home center in the same bin where threaded rod and angle iron are kept. I'm sure brass or alumium rod would work as well. I cut off a 1.7" length of the rod using a hacksaw and deburred the end by rubbing it on a flat file.
Before working on the mower, take off the cover, disconnect one battery lead, and secure it so it can't reach the battery terminal. You don't want the mower to start up while you are working on it.
Now diassemble the switch housing. On the part of the housing where the switch is located, find where the original plastic pin broke off. If the pin didn't break off cleanly, trim it flush with a file or sharp knife, then drill a 3/16" hole to a depth of 0.45". Be careful to center the hole. I started with a small pilot bit, then enlarged the hole to 3/16". Put some tape on your bit to keep from going too deep. The plastic drills easily.
The rest is easy. Insert your replacement metal pin, reassemble everything, and test. Give the rest of the rod to a friend who owns the same mower.
Mar 27, 2010 | Black & Decker 19" Electric Lawnhog...
I have a Kenmore Series 80 washer. It vibrates in the spin cycle every time. Can that be repaired and is it expensive?
I WOULD FIRST SUGGEST YOU LEVEL IT FIRST YOU NEED A SPRIT LEVEL START BY REMOVING THE MACHINE OUT OF ITS PLACE THEN PLACE THE SPIRT LEVEL ON TOP OF MACHINE IF BUBBLE IS OFF THEN GET A SPANNER THAT FITS THE FEET OF MACHINE THEN TURN ONE FOOT AT A TIME AND CHECK THE LEVEL AND DO THIS TO ALL FEET UNTILL THE BUBBLE IS IN THE MIDDEL GOOD LUCK.
Nov 30, 2009 | Washing Machines
Making loud noise when in spin cycle
SOUNDS LIKE YOUR WASHING MACHINE COULD BE OFF BALLANCE YOU NEED TO CHECK THIS WITH A SPRIT LEVEL AND AJUST THE LEGS IF NEED BE .
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
It level and still jumps around we had a repair man come last week to put a clutch or something in and it's done this ever since I can't even use it
THERE IS NO CLUTCH IN A WASHING MACHINE GET HIM BACK OUT AND ASK HIM TO UNDO WHAT HE HAS DONE , GET A SPRIT LEVEL AND CHECK THE LEVEL OF YOUR MACHINE IF IT IS LEVEL AND STILL JUMPS AROUND CHECK THE SAFTEY BOLTS HAVE BEEN ALL REMOVED THEASE ARE FOR SAFTEY TRANSPORT OF THE MACHINE AND ANY LEFT IN COULD CAUSE THIS .
Oct 25, 2009 | Washing Machines
Hitachi 57F500A Projection Color TV all of the sudden is very blurry. Tried magic focus with no help. Checked all connections and there is nothing wrong. All other TV's in house work fine.
Have the convergence IC's replaced in this model. They are the two large Black IC's located on a large alumium heatsink. Have replaced.
Thk please leave comment.....
Oct 09, 2009 | Televison & Video
Ryobi Airgrip Laser Level Logo
138 people viewed this question
Top Ryobi Measuring Tools & Sensors Experts
JOHN LAPIER
Vuk B
ray gallant
Are you a Ryobi Measuring Tool and Sensor Expert? Answer questions, earn points and help others
