Question about DSC GE Networx NX 148E Alpha Programmable LCD Keypad
Reset remote for nx-148e
Remote for nx148e home alarm stopped working after changing battery and cant find info to reset in the manual
Why my alarm want stop going off?
Week or dead battery on your remote. Change the remote battery, got nothing to loose except a couple of bucks
Oct 06, 2014 | 2002 Acura TL 3.2 Type S
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
Jun 25, 2014 | Home Security
We have an NX-148E keypad. Our building has 4 doors alarmed to the panel and the Chime sounds when any of the doors is opened. Is it possible to set the Chime only to sound when 1 of the doors is op
I am sure there is separate programming for each zone. You will need the manual for the system. Probably can get it on line. This chime feature usually comes from the factory with no zones programmed for reporting. Hope this helps
Oct 03, 2012 | GE / Caddx Networx Programmable LCD Keypad...
We have a Network NX148E which was linked to a central minitoring. Just wondering if this can be re programme to link to our mobile instead?
Hello
Yes you should be able to have the system call multiple phone #s.
I would recommend you ask your monitoring company to do this or make a change in your account.To add your mobile #
Once the alarm is set off they need to know first to dispatch police fire or ambulance.
Mar 29, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Can I adjust the volume on my GE Networx NX-148E keypad?
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
Hi i have a ge Caddx NX-148E-RF - beeps only on the hour anoying
Press * 2 and it should tell you what the problem is.
AlarmProfessor.net
Jul 04, 2010 | GE Security Simon 3 Wireless Home Security...
Dont know the reset code or anything about home security alarm sy
need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
Apr 23, 2009 | Electrical Supplies
Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
Feb 16, 2009 | Vehicle Parts & Accessories
DSC GE Networx NX 148E Alpha Programmable LCD Keypad Logo
Top DSC Home Security Experts
yobo007
yobo007
don1956
Level 1 Expert
Terry Weaver
Terry Weaver
Are you a DSC Home Security Expert? Answer questions, earn points and help others
