Konica minolta bizhub 163 c0000
Problem with paper. Not taking paper to proceed print job. Error description : C0000
3 Suggested Answers
  • 1297 Answers
SOURCE: konica minolta d183 error code
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
Posted on Oct 23, 2009
Testimonial: "Thank you. That is what we will try and do."
  • 158 Answers
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Posted on Nov 30, 2009
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
My Machine Konica Minolt bizhub 211 telling me Machine trouble service call C0000 what will i do
Main Motor failure check the image unit and or the paper draws or you have a bad motor worse case the main control board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 05, 2015 | Konica Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
How to remove C0000
C0000
Main Motor malfunction
- The Main Motor (M1) Lock signal remains HIGH for a continuous 1-sec. period at any time 1 sec. after the Main Motor has started turning.
May 27, 2014 | Minolta EP4000/5000 CS/PRO Copier
Error code C0000
Main motor not turning. Check for a major paper jam in the fuser unit. Open the front door and on the left side is the fuser assembly. Push in the green knob and turn the fuser. It should turn rather easily. If not it is jammed. That is the most common cause. Other than that you would need a technician to determine what assembly in the machine that has locked up and thus preventing the main motor from turning.
Nov 23, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error code c0000 in bizhub 210
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
Jul 07, 2010 | Konica Minolta bizhub 180 All-In-One...
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
Nov 30, 2009 | Office Equipment & Supplies
Konica minolta d183 error code C0000
Oct 22, 2009 | Office Equipment & Supplies
What causes the cf 910 to give c0000 and c0042
Hi
Thanks for using FixYa. Error C0000 means Main Motor’s failure to turn and error C0042 means Fusing Cooling Fan Motor failure to turn.
These errors can be due to your fuser getting stuck. Sometimes the upper and lower rollers get stuck together, or a flat spot may develop on the lower roller. Check the fuser rollers, replace if faulty.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
95 people viewed this question
k24674
jasbo
jasbo
