Question about Sharp XE-A402 Electronic Cash Register
Won't function Saying program mode closed
  • Sharp Expert
  • 592 Answers
Press esc button
Posted on Nov 26, 2013
I have a 2003 trailblazer and i bought a fob and it does not work after programing Everything thing works on my truck but the fob. Any ideas?
How was it programmed ? Was a scan tool used ?
Program All Key Fobs
To complete this programming operation, all keyless entry transmitters associated with the vehicle must be available for programming. Once placed into program mode, all previously programmed transmitters will be erased from memory upon the receipt of the programming signal from the first transmitter.
  1. Close the lift gate.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program All Key Fobs.
  3. Follow the scan tool on screen instructions in order to program the transmitters. Select "Start" on the scan tool to enter the program mode.
  4. As each transmitter is successfully programmed, the scan tool will show how many transmitters have been placed into memory.
  5. When all transmitters are programmed, exit the program mode by selecting "Stop" on the scan tool. The vehicle will not respond to the transmitters until the program mode is exited.
  6. Operate the transmitter functions in order to verify correct system operation.
Program Individual Key Fob
If there are less than four keyless entry transmitters programmed to the vehicle, an individual fob transmitter can be added. This method will not erase previously programmed transmitters from memory.
  2. Ignition ON, access the scan tool Lift gate Module Setup menu and select Program Individual Key Fob.
  3. Select "Program additional Key Fob" on the scan tool.
  4. Follow the scan tool on screen instructions in order to program the transmitter.
  5. Operate the transmitter functions in order to verify correct system operation.
Apr 08, 2016 | Cars & Trucks
My Panasonic DMR E S45V just stopped working. The Error message is F04. The DVD door won;t open, the VHS door won;t close.
Check the servo unit to see if the actuator is changing modes when press the buttons. If one door is open the other will not function either.
Feb 02, 2015 | Televison & Video
Bubble Shooter won't run
ok open the start button
control panel
system icon
tell us what the memory and cpu and number of bits(32 or 64) that this panel reports
May 30, 2012 | Computers & Internet
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
HAVING TROUBLE CLICKING ON SOMETHING AND COMPUTER LOCKSUP SAYING CLOSE PROGRAM OR WAIT!!!THIS HAPPENS OFTEN!! HPdv7 6163 i7 windows 7
Probably viruses. Try to load Windows in Safe mode, if everything is OK, there is a problem with system or viruses. Power on laptop, press F8 and hold until you get Windows loading options, and choose Safe mode.
Sep 04, 2011 | HP Pavilion dv9000z Notebook
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
When enter my log 0n I receive this message: Skype has stopped working. A problem caused the program to stop working correctly. Window will close the program and.................. This happened...
Skype changed in the update. You probably have yours set to run in compatibility mode for Vista Service Pack 2. This crashes the program now. Only fix I've found is turning compatibility mode off, which sucks cause it won't minimize to tray. But it runs at least.
May 16, 2011 | Skype IM
Unable to install 3.1 in windows7
install the app as admin. then go to the installed apps propereties and tell it to run as a xp app in compatibility mode
How to Use Windows Application Compatibility Mode Published: October 25, 2001
This article describes how to use Windows Application Compatibility mode. This mode provides an environment for running programs that closely reflects the behavior of earlier Windows operating systems.
Using The Windows Application Compatibility Mode
When you use Windows Application Compatibility mode, many of the most common issues that prohibit earlier versions of programs from working correctly are resolved. If you run a program and it does not function as expected, it is recommended that you run the program in one of the compatibility environments.
To run programs in Windows Application Compatibility mode in Windows XP
  1. Right-click the icon of the program that you want to fix.
  2. Click Properties.
  3. Click Compatibility tab.
  4. Click Run this program in compatibility mode and select one of the following options:
    • Windows 95
    • Windows 98 / Windows Me
    • Windows NT 4
  5. Under Display settings, check the mode that you think is necessary for the program to work correctly:
    • Run in 256 colors.
    • Run in 640 X 480 screen resolution.
    • Disable visual themes.
  6. Click Apply.
  7. Click Ok.
  8. Double-click the program icon.
    Note The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program. For more information about an option on the Compatibility tab, right-click the option and then click What's This.
Oct 30, 2010 | Primavera Project Planner P3 (PRIMAVERAP3)...
I can not delete a download called,freeride games player. It keeps saying the program is running, that I should close the program, then return to control panel to delete. I have deleted all referance to...
Start the computer in safe mode by pressing f8 as the first screen appears and selecting safe mode.
it will start slower than normal , and when it does , uninstall , not delete the program in question. if you just delete the directory, it will leave junk installed you dont want. Sooo unistall it from it's own uninstall program or from the "add & remove programs" section in the controll panel.
Oct 23, 2008 | Computers & Internet
Sharp XE-A402 Electronic Cash Register Logo
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
