Question about Vacuums
Bosch formula hygienixx 1800w
Replacement brush head
Hi my bosch ergomaxx 1800w vacuum cleaner isn't
Some of those machines have a breaker button on the back of the body that needs to be reset. It will be located on the back bottom part of the body housing.
Sep 05, 2014 | Vacuums
Bosch 2607022999
Can't replace the brushes on t his DC motor. Have to get a replacement motor. They run about $70 at ereplacementparts.com at this writing. Direct Current Motor
Nov 19, 2013 | Bosch 2607022999 Direct-Current Motor
Bosch hygienixx formula bsg71266gb/07.Lost my manual and would like a copy. Also can't work out how to empty the bag.
Hi. Visit http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html and follow the link to add the model number in. Also if no joy there contact Bosch UK - they will be happy to help you. Generally this vacuum has a bin door at the top that opens up towards the owner. The hose will have to be removed and the latch is behind the handle. Thereafter the bag can be slipped out and replaced.
Oct 29, 2013 | Bosch Vacuums
The brush doesn't turn when I tried to clean the carpet.
Easiest fix would be to check to see if the belt is broken or not moving. If it is not broken yet not moving then most likely the brush that it turns is frozen. Follow the directions to change the belt. Once you get the brush out of the unit clean it as best you can. Spray some WD40 on the plastic tabs at the ends that hold it into the vacuum head. When reassembling, might as well add a new belt.
If you find this solution to be of help, I would appreciate a Thumbs Up rating from you. Paul
Oct 11, 2010 | Bosch 12-Amp Formula Canister Vacuum with...
Bosch Formula vacuum cord stuck
You need to take apart the reel. The cord is wound over itself and kinked. Be careful taking apart because if it gets away from you, you will have to wind the spring by hand and it is difficult to do and frustrating.Good luck
Jul 26, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Bosch premium Duo 'H, brush won't spin
Hi - this procedure may work.
Switch off the Bosch and take off the main power head. There should be screws or a flap on the base in which the roller brush can be taken out or inspected. Check the internals and make sure nothing is clogged - if there are toothed wheels at the end of the beater bar on each side, take it out and clean it if it is clogged with dust. Alternatively check the main turbine as it may be stuck down with dust that needs to be de-clogged. Then check the main hose mount that meets the floor head in question - check that the metal strip connection has not corroded. Hope this info helps.
Don't forget to rate, thanks.
Mar 04, 2009 | Bosch BSG81370UC Premium Duo Health Guard...
Samsung jet propel 1800w power clean vacuum not sucking in/picking up on main front edge roller whilst the hose / attachment does have plenty of suction when taken out of its dock
Just had the same problem. Turns out to be the belt that spins the brushes...
Check to see if the brushes are spinning, if not, undo the four screws on the plate over the brushes and the belt is easy to get at. Replacement should be available in any spares store.
Jul 05, 2008 | Samsung Vacuums
My bosch turbo jet vacuum
open the head. there is a dc 120 v motor with a belt.
check for ac power going in to the rectifier board and dc comming out.
sometimes the black wire breaks inside the motor housing.
it is hard to open and close the motor housing side where the wires run and closing the power head is fun as well.there is a transformer for the light and wires have to be routed just right to close it up.
good luck
Paul G. Canada
May 07, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Bosch vacuum
check the belt, it might be stretched or broken
or carpet fibers and hairs may have clogged up the brushes to keep them from rotating
let me know if this isn't the problem
Mar 22, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Vacuums Logo
16 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
