Question about Cooktops
Ideal zanussi z 935 x
Free download maintenance manual for ideal zanussi washer Z935X
Back L element no go
Feel free to download a copy of your wiring diagram from http://sparepartspro.zendesk.com/entries/118713-zanussi-electric-hob
Qualified Electricains only.
Feb 24, 2010 | Zanussi 23 in. ZKT641H Electric Cooktop
When i switch my zanussi hob on L comes up on all 4 zones.Could you tell me what is wrong Model no.ZKT641F.
Turn on so that all are showing L
Then press - for 5 seconds when all should show 0 then turn off.
Upon turning on all should be fine.
Sep 09, 2009 | Zanussi 23 in. ZKT641H Electric Cooktop
Child lock has come on and I have no instructions to get it back to normal
JUST HOLD DOWN THE CHILD LOCK BUTTON AND THE ON BUTTON SIMUTANEOUSLY FOR ABOUT A MINUTE OR 2. THIS SHOULD RELEASE IT
Aug 25, 2009 | Zanussi 23 in. ZKT641H Electric Cooktop
Electronic igniters won't shut off.
Boy, I had a Thermador that used to drive me bats.
The best solution was to clean around the ignitor pin and make sure the orifices closest to the ignitor are not blocked... It made a big difference.
I used a small fine metal bristle brush.. did the trick.
May 30, 2009 | Bosch 36 in. NGT 935 Gas Cooktop
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
93 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
