Can anyone tell me how to open a Brother M-1500 typewriter so I can replace the ink spools? Or direct me to its manual? Thanks!
It's a bit tricky. I opened mine by first prying open a gap between the plastic and the base just under the spacebar, and then lifting the rest of the plastic cover off from there. It requires a lot of playing and will feel like you're forcing it uncomfortably sometimes though.
Posted on Nov 24, 2013
2 Suggested Answers
  • 20 Answers
SOURCE: brother sx-400 eraser not working
It can only use the brother dry lift-off # 3015, I think, shining side faces you.
Posted on May 01, 2007
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
Directions arent clear enough in manual to change correction tape
Install the full spool on the L. side thread the tape around the guide rolls with the dull side towards the paper, put take up spool on R. spindle, wind up slack.
It may be easier if you remove the ribbon and print wheel first.
DickyO
May 24, 2011 | Brother EM-530 Typewriter
What type of ribbon is compatable with a model 762 tr
http://www.fjaproducts.com/SearchMe/7540.asp?unConResults=8209
Regular Price: $15.95 ea.
Our Price: $9.95 ea.
Availability: This item ships within 1 - 2 business days. Next Day shipment method is Not Guaranteed.
Type: Compatible
Product ID: 7540
Description: This is a Solid Black ribbon. This Black Twin Spool Typewriter Ribbon is .5 In. x 24 Ft. The Spool Diameter is 2 inches.
This Black ribbon is designed to work with all of the following machines:
BROTHER 1500 ? BROTHER 2000 ? BROTHER 210 ? BROTHER 220 ? BROTHER 240T ? BROTHER 250TR ? BROTHER 262TR ? BROTHER 3060 ? BROTHER 3800 ? BROTHER 600 DELUXE ? BROTHER 650TR ? BROTHER 660TR ? BROTHER 662TR ? BROTHER 700 DELUXE ? BROTHER CHARGER11 ? BROTHER CHARGER11 C ? BROTHER CHARGER12 ? BROTHER CHARGER2000 ? BROTHER CHARGER2512 ? BROTHER CHARGER3000 ? BROTHER CHARGER3012 ? BROTHER CHARGER3500 ? BROTHER CHARGER4512 ? BROTHER CHARGER 750 TR ? BROTHER CHARGER 762 TR ? BROTHER CHARGER 850 TR ? BROTHER ELECTRIC PORTABLE ? BROTHER STANDARD PORTABLE ? BROTHER XL1010 ? BROTHER XL1012 ? BROTHER XL3112 ? BROTHER XL3612 ? BROTHER XL4612
Jan 19, 2011 | Brother Office Equipment & Supplies
I have a brother typewriter and i lost the manual to it. where can i buy i need to replace the ribbon i replace it but it does not type, the ink does not show please help me thanks
As you don't specify a model, I can't help you directly.
Please go to this website:
http://www.brother.ca/en/customer_care/user_manuals.asp?id=3428757312013072692
select Typewriters in "Select Category" and choose your model in "Select Model" and you will be able to download a manual for your unit, or a similar one.
Good luck, and don't forget to come back with a testimonial if helped :)
Dec 09, 2009 | Computers & Internet
Old typewriter Brother DELUXE 800 : ribbon reference ?
This is what you are looking for:
Brother Typewriter Ribbon spool black and red SC-20BR-BRO Compatible
The typewriter ribbons for use in Brother manual typewriters are usually all the same. What matters is the size (diameter and hight) of the spools.They differed only in that they were available in different colours (usually black or black and red) and in different materials: some ribbons were made of nylon (cheaper) and other made of silk (more expensive and higher quality) .
Maybe some old and good stationer's (papeterie) still carries them or has some in stock.
Or else you may want to contact the customer support service of Brother, in France, for advice on where to find them in your Country.
Sep 07, 2009 | Brother Office Equipment & Supplies
Installing ribbon for an old portable Brother typewriter
Make sure the ribbon is on in the right direction being pulled not pushed off the spool
Dec 27, 2008 | Olivetti Lettera 25 Typewriter
Correction spool
The feeder spool goes on the pin to the left of the carrier with the sticky side toward where the paper would be. Feed it through the ribbon guide and then attach the other spool on the pin on the right. Be sure both spools are snugly snapped into place - mine kept flying off.
Sep 17, 2008 | Brother SX-4000 Typewriter
How do I put in new ink cartridge??
Get yourself a new ribbon Gen. Ribbon T-340 and a lift off Gen. Ribbon T-350 the lift off snaps onto the bottom of the ribbon and then both go on the typewriter there are two small tabs onthe ribbon cassette that go into notches on the front of the ribbon deck then the unit snaps down in the back held by the blue latch.
DickyO
Aug 04, 2008 | Lexmark Wheelwriter 1500 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
62 people viewed this question
k24674
