Question about Sharp CS-2850 Calculator
Casio FR-2650A We cannot get the calculator tape into the machine. Crazy, Huh?! There is one slot at the back of machine but the paper goes nowhere. I hate to take the top off (screwed on)...any ideas? Thanks Donna L. Auman
  • 6 more comments
  • thwnhn Dec 31, 2007
    I have the same problem. The machine seems to be faulty.
  • Angel7379 Jan 07, 2008
    We can not figure out how to load the print paper into this crazy thng, anyone have a solution?
  • Anonymous Feb 27, 2008
    CANNOT FEED THE PAPER IN!!!
  • Anonymous Aug 04, 2008
    I have tried the solutions that were suggested, and I find no paper blocking the feed but it still will not load the paper. Any other suggestions besides buying a new machine?
  • Anonymous Jan 26, 2009
    FR 2650A I have the same problem cfan not get it to feed the paper, I think Casico should replace these at no cost to us
  • akerwick Apr 16, 2009
    No matter how much I try I cannot get the paper in!! Very frustrating!!
  • denden22 May 26, 2009
    I folded the tape back to make a point on one side of the tape. It went through by pushing and hitting the FEED button many times. However, now it won't feed automatically when on the print selection, nor when hitting the FEED button. One issue resolved, now working to resolve a new one. Anyone run into this? Resolutions?
  • Anonymous Mar 14, 2014
    How to loab the paper tape in a Casio FR-3100
  • 3 Answers
The tape goes into a small slot on the backside of the machine, not in the clear plastic cover. Install the roll so the paper rolls off the bottom, not over the top. Folding the paper back about 2" does help you get it through.
Posted on Feb 01, 2008
    Champion:
  • 204 Answers
I agree..make a fold like a point and push it in the back slot while pressing the paper feed button...should feed or you have some other paper caught in there
Posted on Feb 05, 2008
I am having the same problem as well. I tried to fold the paper and stuck it into the slot and pressed the feed button several times and it is still not working, Help!!!
I tried all methods you suggested, but no avail... This is one of the dumbest machines I have ever had.
  • Mike
    Mike Jun 14, 2018
    I couldn't agree more - POS
Make a fold on your calculator tape and stick it in the slot. Press the feed button several times.
Posted on Nov 21, 2007
6ya staff
SOURCE:
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Operation instructions
Manual Center has the manual available here: http://www.manualscenter.com/manuals/casio/fr2650a-owner-manual.html#.VP9lNuOFr3g . You may be able to read the manual without paying for a downloaded copy. (The manual page images are on-screen but the font is small.)
I hope this helps.
Mar 10, 2015 | Casio FR-2650A Printing Calcultor P/N:...
Casio FR-2650A Not Pulling Paper Through
See if the roller gear is jammed or rusted. A little wipe with WD40 may help.
Jan 27, 2012 | Casio FR-2650A Calculator
How to install adding machine tape to a radioshack EC-3033
Here is the link to the instruction book for that calculator. It describes how to install the paper into the machine. The only thing I could recommend different is to fold the lead edge of the paper to a 45 degree angle /| instead of the straight edge the book is recommending. Sometimes there is a small blockage in the feed path and the angled fold will get the lead edge passed it enough for the feed rollers to catch the paper. The blockage usually feeds out with when the edge of the paper clears the rollers. I would try it by the book first then try the folded edge. The only other option would be a middle fold /\ in case the blockage is on the edge you folded from in the first attempt
Link to EC-30333 book
http://support.radioshack.com/support_radios/doc46/46048.htm
Hope that helps
Jun 12, 2010 | Casio FR-2650A Calculator
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Jul 18, 2009 | Casio FR-2650A Calculator
FR-2650 Plus adding machine
How to install paper tape on a adding machine?
Apr 27, 2009 | Casio FR-2650A Calculator
Casio FR-2650A
I have lost my manual. I can I thread my Casio Calculator FR2650a?
Aug 06, 2008 | Sharp CS-2850 Calculator
Load paper
You must feed it through the back of the machine while depressing the feed key. make sure it is the right size paper and hopefully there is not a jam in the machine. If so you can try sliding a business card through the slot where the paper goes and force any jammed paper out of the path.
Jun 01, 2007 | Casio FR-2650A Calculator
Sharp CS-2850 Calculator Logo
1,652 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
