Question about Breville 2400w Steam Iron Stainless Steel Soleplate
Cleaning instructions for breville steam iron
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: My Breville Jet Select Iron
Almost all iron instructions suggest using a DE-SCALE once in a while.
Depending on your water type (hard/soft) would give you a guide as to how frequent.
Most supermarkets carry some form of descale liquid
in canada CLR is a good choice
many big box stores also carry it in the appliance areas.
you dont need much and as little as 250Ml will see you for a long time.
I prefer to descale items with a full load of water at the hottest setting
Allow for addition of at least 10% descale
let it sit for about 20 minutes then pour the water out and rinse out well to remove any debris
I often do that twice in case of stubborn deposits.
If yopu ever descal a kettle or tea maker, coffe maker then rense out extra well with cold water to make sure you remove all trace of the descale.
Posted on Mar 02, 2011
ercupa190
  • 12223 Answers
SOURCE: how do i self clean a breville iron
pleasle use the owner manual for see the self clean. download from www.fitness.manualsonline.com or www.retrevo.com and proceed accoridng.
God bless you
Posted on Jul 23, 2012
ercupa190
  • 12223 Answers
SOURCE: how do i use the self clean on my breville steam iron 2400 technique
please refer to the owner manual for use. download from www.fitness.manualsonline.com or www. retrevo.com
God bless you
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
Breville TECHnique VIN158
if the iron use electronic control, will be a little difficult to adapt or reset .However i recommend follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Breville VIN 214 iron leaking - can anyone help please
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Black & Decker Prestige X805 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
How do i self clean a breville iron
God bless you
Jul 22, 2012 | Breville Power Steam VIN208 2400 W Steam...
How do i use the self clean on my breville steam iron 2400 technique
God bless you
Cant get anti calc cartridges for my steam generator
I had to order mine direct from Breville. If you go to their website and contact them with the model of the iron then they will give you details of price and postage.
Aug 25, 2008 | Irons
Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Dec 23, 2007 | Irons
Breville 2400w Steam Iron Stainless Steel Soleplate Logo
26 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
