Remote codes lg 55lm4600 - Televison & Video
I have a LG model#55LM4600-UC the TV comes on it has sound but no picture
That could be the T-Con board that has failed. You need to get the right board, but they can be replaced.
May 25, 2018 | LG Televison & Video
My LG 55lm4600 tv has lost HDMI inputs 1 and 2. The HDMI input 3 and AV/TV inputs work. The remote has also stopped working.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ....
Aug 27, 2016 | LG 55LM4600 55 Inch Cinema 3D 1080p 120Hz...
LG 55LM4600-UC has no video and no audio but is getting power what could this be?
Jul 13, 2016 | LG 55LM4600 55 Inch Cinema 3D 1080p 120Hz...
LG LED backlight on but no image
check the cable to the display and then check the inputs to the TCON from the signal board.
Jun 19, 2016 | LG 55LM4600
I have an LG 55LM4600 smart TV. We got thru rent a center. I try to use the "smart" functions it comes up and says "No Storage Units Available" I've called rent a center they tell us it's the remote
I think it's talking about storage units such as USB drives. You can put movies/pictures/mp3s and such onto the USB drive and the TV would be able to play it thru the USB port. Also be sure to check out the owners manual. If you didn't get one you can download/view it here: http://www.lg.com/us/support-product/lg-55LM4600 .... Hope this helps.
Aug 24, 2015 | LG Televison & Video
How do I test for a black screen on LG 55LM4600
If audio is OK, the problem is with its back-light inverter board. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 06, 2014 | LG 55LM4600 55 Inch Cinema 3D 1080p 120Hz...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
