Question about Xerox Phaser 8500/DN Printer
The front panel shows nothing
The printer still prints however the front panel display is blank and shows nothing. i'm not sure what to do. thanks
  • 23 Answers
When our control panel went blank last month, Xerox did not offer a free replacement because our printer was out of warranty. Consequently, we ordered one from SparePartsWarehouse.com at the best price we could find - $104.87 plus shipping. The part number for our 8550dp is 848K06551, but these are the compatible part numbers for the "Xerox 8500 Control Panel & Bezel": Compatible Part Numbers: 848K06551, 101E28730, 101E28731, 802K93650, 802K93651, 848K06550, 848K06552. It is easy to replace, instructions are on the Xerox website at http://www.office.xerox.com/printers/color-printers/phaser-8500-8550/sprt-enus.html
Hope this info helps someone, and thank you FixYa for this forum.
Posted on Sep 26, 2008
  • rubenduran4 Dec 06, 2010
    I just called 800-835-6100 and they are sending me a free replacement that will arrive in 3-4 days at xerox's expense. They also confirmed this was a common occurance with the Xerox Phaser 8500. Hope this helps someone.
    Novelist:
  • 208 Answers
Contact Xerox, there is a known problem with the 8550 UI.
They will replace it free of charge.
Posted on Dec 10, 2007
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
The display panel has gone bad and must be replaced. This video shows you how to fix it. Very easy and no tools required ">
Posted on Jan 29, 2011
Hi i think the led is not working properly, u can definitely get it repaired by an engineer.however it wont harm u even if it doesnt work,it just makes it user friendly.
Posted on Aug 30, 2007
Display panel blank
No fuse, if you replace the display and you are sure that the display is good, then the controller or motherboard that the display plugs into is bad.
Dec 11, 2015 | Office Equipment & Supplies
Changed ink, now display panel is blank and nothing prints
You need to change your black ink cartridge so that they cannot print. Just check the ink level of your printer then replace the cartridge if they're needed. Make sure that the cartridge you have change are the same and compatible with your printer. Because if they are not compatible with your printer it will not recognize the cartridge.
Jun 03, 2010 | Canon MP520 All-In-One InkJet Photo...
Xerox 8550 DN display does not work and printer does not print
This model of printer has a known fault with the LCD panel.
Contact xerox in your country, who will arrange to have a replacement front panel sent out to you to install
Aug 03, 2009 | Xerox Phaser 8500/DN Printer
Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Sep 21, 2008 | Xerox Phaser 8500/DN Printer
The display panel needs to be replaced. The part number is 802K93650. We sell them for $160 plus shipping. Our number is 574-243-1176 if we can help.
Jul 23, 2008 | Xerox Phaser 8500/DN Printer
No display and no light indicators when powered on
If the printer control panel is blank when you turn on the printer, check the following items.
1. Make sure that the printer is plugged into an active electrical outlet that delivers the correct
voltage.
2. Make sure that the on/off switch is in the on position.
3. Make sure that the fan runs briefly, which indicates that the power supply is operational.
4. Make sure that the control panel display wire-harness is connected.
The control-panel wire-harness connector can easily be disconnected when you install the top
cover. If the control panel does not work after the top cover is installed, verify that the wire-harness
connector is fully seated into its DC controller PCA connector.
5. Make sure that the firmware DIMM and the formatter are seated and operating properly.
6. Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
If the printer control-panel display is blank, but the main cooling fan runs briefly after the printer
power is turned on, try printing an engine test page to determine whether the problem is with the
control-panel display, formatter, or other printer components.
Engine test page
To verify that the printer engine (all printer components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine test page. Use a
small, non-metallic, pointed object to depress the test-page switch, which is located on the right
side of the printer
The test page should have a series of vertical lines. The test page will print from the last tray you
printed from. However, if the printer has been turned off and then back on since the most recent
print job, the page will print from tray 2. The printer will continuously print test pages as long as
the test-page switch is depressed. The printer will not print a test page if it is in PowerSave
mode.
A damaged formatter might interfere with the engine test. If the engine test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then
successful, the problem is almost certainly with the control panel, or the cable that
connects it.
Hope this helps
May 24, 2008 | HP LaserJet 4250n Printer
Front Panel Display is Blank - only small black squares
the front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Jan 06, 2007 | HP PSC 2210 All-In-One InkJet Printer
Xerox Phaser  8500/DN Printer Logo
949 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Clive
Clive
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
