How do u change the battery in a Bulova miniture clocks? I have 2 model number B0501 &B0555. Took the cap off then the pressure clamp and didn't dare to pull on the silver part which I think is the battery. But id rather ask then ruin them cause they are so cool. Ok ok the wife would kill me!!! Lol THANK YOU FOR YOUR TIME AND HAVE A GREAT DAY! MY EMAIL tadheath95@gmail.com
SOURCE: xp drivers for c771tu
Intel Chipset,(install and reboot before other drivers):
http://tinyurl.com/2vdz3e
Intel X3100 Graphics:
http://tinyurl.com/5jgktf
Alps TouchPad:
http://tinyurl.com/2v4drk
.Net Framework(before Q.L.):
http://tinyurl.com/758p8
HP Quick Launch (Volume buttons):
http://tinyurl.com/5om4px
Atheros Wireless:
http://www.atheros.cz/download.php?atheros=AR5006EG&system=1
MS UAA (required with a reboot before Conexant):
http://www.mediafire.com/?4ben9zlesng
Conexant SmartAudio 221:
http://www.mediafire.com/?dg0cmmkm4y4
Unzip to a folder.From Device Manager,right click "Audio Device on HD",choose Update driver,
No to connect,
Install from a list or specific location,
Select Don't Search, I will choose the driver to install,
For the Hardware Type select 'Show All Devices'
Remove the check from "Show Compatible Hardware" and click on "Have Disk".
Next...browse to the unzipped folder and choose the "WiSVHe5.inf".
Ignore XP when it complains.
Reboot.
Soft Data Fax Modem:
ftp://ftp.hp.com/pub/softpaq/sp37501-38000/sp37982.exe
Posted on Jul 15, 2008
SOURCE: Time Changes
How can i changed our clock for daylight saving time.My clock change 1 hr back this morning 1024.
How do i fix this.Clock is about 3-4 yrs old.Thank you
Posted on Oct 24, 2008
SOURCE: Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Posted on Mar 08, 2009
SOURCE: Front camera problem
press * # 0 * # and then press 8 your front camera will ready.
Sakthivelan.B
Posted on May 07, 2009
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Posted on Jul 03, 2009
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Best way to take it off
Acura Coupes and Sedans 1986-1993 Repair Guide
Fuel Filter
Print
The recommended change interval for the fuel filter on all models is 60,000 miles under normal service. Severe service will require more frequent changing of the fuel filter.
The filter is located in the passengers side of the engine compartment.
CAUTION Before disconnecting any fuel lines, be sure to open the gas tank filler cap to relieve any pressure in the system and wrap a shop towel around the fuel line fitting before opening. Observe all fuel handling precautions.
REMOVAL & INSTALLATION
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Wrap a shop towel around the fittings and using a proper wrench, slowly loosen the fuel line fittings.
  3. Remove the 2 banjo bolts from the fuel lines.
  4. Remove the fuel filter clamp retaining bolt and the clamp.
  5. Remove the filter from the vehicle.
It is very important that ALL of the fuel line banjo bolt washers be replaced every time the banjo bolts are loosened. If the washers are not replaced the fuel lines will leak pressurized fuel causing the risk of fire or explosion.
  1. Install the new filter in position and tighten the clamp mounting bolt to 7 ft. lbs. (10 Nm).
  2. Attach the banjo fittings with new washers in place. On Legend and Vigor, tighten the fuel line flare connector to 28 ft. lbs. (38 Nm). On the remaining models, tighten the banjo fitting bolts to 20 ft. lbs. (27 Nm).
  3. Start the vehicle and check for leaks.
Fig. Fig. 1: Disconnecting the fuel lines from the fuel filter
Fig. Fig. 2: Fuel filter replacement-1991-93 Integra
Fig. Fig. 3: Fuel filter replacement-Legend and Vigor
Jul 08, 2012 | 1991 Acura Legend
What do the numbers C837317 on the back of my ladies Bulova watch mean? The watch looks similar to the Bulova 98R98.
On the back are the specific "case" number. The numbers on the dial below the 6 o-clock position are the "model" number.
Oct 04, 2011 | Bulova Watch
I picked up a Bulova "8" clock at a garage sale and the it doesn't run. Looks like an annivesary desk clock. I took the back off and I don't see any place for batteries. There is a "Time...
If it is a spring driven clock, then there should be a hole with square shaft in the middle.
On larger clocks the hole is at the front but as yours is a desk clock, the hidden inside the back sound a reasonable alternative.
If there is no key, then you should be able to get one from a clock shop.
Mar 19, 2011 | Watches
Where is the drainedge for the radioter
For a 2001 Buick Regal GS 3.8 Liter, Supercharged engine:
First, let engine cool some. Second, locate small drainage hole at the bottom left/drivers side, of the radiator. From the bottom of this small drain hole, go straight back toward rear of radiator, then up about 1 1/2 to 2 inches up. (Have a drain pan or pail handy, to catch the old antifreeze.) You'll find a dark colored drain nut. Use a larger, correct sized socket ratchet wrench & loosen this fitting a turn or so, counter clockwise. Old antifreeze will begin to come out the bottom drain hole. The more you loosen the fitting, the faster the fluid flow out. I wouldn't remove the drain plug completely, or you'll loose control of the draining flow rate.
I just changed my anti-freeze just last week. I also changed the 2 large radiator hoses & smaller 2' overflow hose at the same time, as long as I was doing the job. They had never been changed before. I also used new hose clamps & a small packet of "radiator hose grease", from Autozone.. I drove the car up onto front car ramps to make it easier. I used safety jack stands for extra care. " You-Tube" shows some, "how to videos", that are helpful.
The old hose clamps are difficult to get to. (You'll need a few tools, some time & patience.) To get to the upper clamp, near the right/passenger side of the of the car, near the battery, I removed the outer serpentine belt & tension pully. I then removed the factory installed spring tension clamp, with the help of an adjustable battery pliers. The bottom of this hose wasn't too bad to get to. On the left/drivers side of car, remove black air intake box to access upper clamp. Remove the black metal brace bar, the will allow access to the air intake black box.
I also changed the small overflow 2 foot long hose & 2 clamps, that goes from radiator cap area, back to the overflow white plastic tank, close to passenger firewall. I removed the overflow tank to clean it out as well. I drained the fluid & changed the 3 hoses & clamps. I then placed all removed parts back where they belong, including white plastic overflow tank, tension pully & outer serpentine belt, air intake black box & metal diagonal brace, contacting air intake box. I flushed the system with some Prestone Radiator Cleaner & clean water. Start car & get up to temp., then run for about 10 minutes. Let cool, then drain again. I flushed my car at least 2-3 times after this, until the drain water ran clear.
The best price on a 5 year/150,000 mile anti freeze, came from Wal-Mart. I then mixed about 50/50 with Distilled water, as suggested on the bottle. All went well & no leaks! I took my time and did a thorough job. Good luck!
Jan 16, 2011 | 2001 Buick Regal
My Grand Prix is 1996 2 door and it is over heating but there is water and antifrzze in it what can i do to fix the problem the owner before me had it sitting for 2 years and they had took out the...
There could be a number of problems. The first is a ceased thermostat. Change it. The water pump impeller may be loose & not pumping enough antifreeze through the system. Change the water pump. The rad may have excessive loose fins. Change the rad. Pressure test the rad cap to see if it is holding the proper pressure. Check the serpentine belt for wear & slippage.Change belt if necessary. Pressure test entire system for other leaks i.e. head gasketetc. Good luck!
Oct 18, 2010 | 1996 Pontiac Grand Prix
How much is a bulova watch worth serial numbers are 5n0211
anywhere from $150-$1000.00 depending on the model number. new watch prices
Mar 21, 2010 | Bulova Watch
Putting back on timex watch
There is a press to put this back on.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Bulova Watch
I have a Caravelle Bulova watch #48G33 and I need to change the battery. I took it to a jeweler and he mess up the back and told me he did not have a battery that fit. I think he was unable to get the back...
Hey there !
if the back has a notch on the top left of the cover (right underneath to what would be 10'oclock position), it is a 'Pop-up'. But if the watch has 6-8 notches on the back plate of the watch its a screw-off.
Its really hard to say what battery size it would take due to the fact that each watch has a different operating mechanism and its hard to determine that from the model number.
Dec 23, 2009 | Caravell Bulova Caravelle watch
49 people viewed this question
 Grubhead
Grubhead
