Question about Toshiba Computers & Internet
For some reason, whan i set it on wireless buten shate duwn the laptop what is the resn
My laptop is LAN is work properly the only problem is wireless when i start/on wireless Bethune all system is trend off so i need to use wireless network
smeago1
  • 136 Answers
SOURCE: New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Posted on Jan 08, 2008
SOURCE: my laptop cannot connect to my local network (LAN)
SHOW WITH ICONS IT IS VERY EASY TO USER
Posted on Sep 04, 2008
  • 8 Answers
SOURCE: TP-LINK WR642G Problems with wireless connection.
Is your wlan & internet light lit?
Posted on Sep 09, 2008
SOURCE: toshiba laptop A25 integrated ethernet and wireless lan not working
Right, you need to click
>Start
>Computer
>Vista C
>Toshiba
>Drivers
>WLAN
>Realtek
Then find a file called Setup, there may be several. You are looking for the one which is an Application. Mine is around 450kb in size.
Double click it to correctly install the Wireless adapter.
Follow the instructions on screen. This should take no more than 90 seconds from start to finish.
Good Luck
Posted on Dec 28, 2008
mail2pvs
  • 390 Answers
SOURCE: turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
two things you may wanna check
if the wireless is enabled in your network settings
and 2nd may be there is a Fn key +some other key combination for the wireless
Posted on Jul 24, 2009
Belkin wireless stopped working - when re submitting WEP password, just says timed out
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 13, 2013 | Belkin Computers & Internet
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
My acer aspire 5050 cannot connect wirelessly to my DLink DI-514 router. It says cannot connect for an unknown reason.
Try RESETTING the DLink back to the default setting and set it up again.
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 24, 2011 | Computers & Internet
LAN connection won't work, but wireless does
It sounds like the LAN card may be going bad. You can see if manually setting the IP address in the settings of the LAN card will work. If that works, then the card's routine for negotiating IP address assignment is corrupted. You maybe able to get some more useful life out of it by doing this until you can replace the LAN card itself. If you need more instructions on how to set the IP address manually, reply back and I'll try to step you through it.
May 01, 2010 | Computers & Internet
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Wifi isnt working the lights not on what do i do
See to it that your Wireless LAN is installed in your LAPTOP correctly, at this point if your LAPTOP have Wireless LAN and not installed properly cannot connect to the network & even your network icons does not appear, its useless.
Go to your Control Panel and and select icon SYSTEM then go to DEVICE MANAGER, you can see their your WIRELESS LAN device is working properly and if not install it using your Utility Disc of your LAPTOP, hope this might help you, good luck!
Jul 29, 2009 | Toshiba Satellite A15-S127 Notebook
Turn on radio button of my wifi NEC VersaProVA11J Laptop.Please H
Jul 24, 2009 | Computers & Internet
I have an acer aspire 4310 laptop wireless lan not working
adapter driver is missing, this method is not completely downloaded the wireless lan driver... you download the software driver properly with all the support-in motherboard chipsets... to make it sure that the laptop is recognized the wireless lan card inside. Good luck!
Im sure you a CD Disc Utility for the ACER Aspire 4310..
Jul 12, 2009 | Computers & Internet
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Wireless set up
as long as your home wireless network is 802.11g (as opposed to a or b ). I see no reason why that should not work.
all you should need to do is install the software first, then plug in the usb wireless adapter,  once that is done you should then be able to "discover" the local wireless networks, select YOUR network from the list (you may need to enter security details if a WEP key is used), once that is done then all you need to do is change the connection settings in Internet Explorer to "Dial if LAN is not available" and change the LAN settings to "Auto detect settings"
I hope this helps :D
Oct 25, 2007 | Toshiba Satellite 1805-S204 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
