Question about LG Lsb316 Sound Bar With Wireless Subwoofer
Button standby Standby button red but won't turn on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • LG Master
  • 924 Answers
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Nov 01, 2013
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
MY LCD PHILLIPS MODEL 42PFL3704D/47
Good day!!!
if you have power problem without blinking lights or standby lights (red) the possible problem is power supply board..However if the TV have blinking or standby light but won't turn ON..there are multiple cause of that and need further troubleshooting..
Mar 11, 2012 | Philips 42PF9431D/37 TV
Hi I just moved plugged in my ps3 the red standby light came on and now nothing it won't even try to turn on what should I do ?
Sorry I had no idea you sent me this message until today. I apologize for the delay. You probably found a solution by now but if you haven't, please try this..
Solution:
  1. With the PS3 in Standby mode (Red light on), press and hold the Start button until you hear a single beep, followed by double beeps.
  2. Connect the controller using USB cable and press the PS button on the controller.
  3. Now, the system restore screen (or whatever they call it) will come up like this
  4. You have several options here for restoring the system, some will unfortunately wipe up all your data, others will make you lose the file naming.
I hope this helps :D
Oct 24, 2011 | Sony Playstation 3 (PS3) Console
LG Lsb316 Sound Bar With Wireless Subwoofer Logo
272 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
